Being that the front fender was painted off the car and in a vertical position (I think headlight end up), overspray would be seen on the inside edges, but covered after installation and the front wheel sound deadener applied so "seen" would be with the wheel off and/or up on a lift, and then not much. Sound deadener for the rear wheel was applied at the same time, over paint. I assume the painter was not a rookie and did a good job. Jeff's photos show the actual results and plant particularities. The intent was more than the actual.
Let me correct the timing, the rear wheels sound deadened was applied at the same station as the inside of the trunk on the fenders, then painted.
