Author Topic: Body filler  (Read 1318 times)
Offline ruger
Body filler
« on: December 30, 2015, 11:50:05 AM »
Just wanted to say that I have used Bondo and Evercoat Z-Grip in the past.  I went with a suggestion to try Evercoat Rage Gold.  Wow,  what an improvement.
This stuff spreads easy and more importantly sands easy.  I am six years older than the last time I done some sanding and was dreading this part of the build.  I am very impressed with the product.  I started sanding with a long block and literally thought I was holding a power tool.
Just wanted to pass this along as it saves time and energy.  Just a precaution though.  You can cut through it very quickly with 80 grit so be careful to not take too much off.  Something else I would like to pass along,  I went to Lowe's and found that the drywall sand paper works just as good as autobody sand paper and is half of the price. I couldn't tell any difference when compared to the 3M paper I had from previous projects.
Happy New Years folks.
1969 Sportsroof Mustang E'
63D
250 six cyl.
C4 trans.
Dearborn build Nov. 1968
Offline mtinkham
  • That'll be easy
Re: Body filler
« Reply #1 on: December 31, 2015, 01:13:34 PM »
Thank you....dreading that stage myself.  I will try the Rage
Offline mtinkham
  • That'll be easy
Re: Body filler
« Reply #2 on: December 31, 2015, 01:17:59 PM »
By the way...anybody see any of the Youtube videos of the guy using the blade for perfect bondo shaping....
