Author Topic: 1970 Mach 1 AM radio  (Read 3645 times)
Offline Rbisch4
« on: December 29, 2015, 11:43:05 PM »
Anyone know which AM radio was installed for 1970 Mach 1 built in Metuchen 10/69?  Part number?
1970 Mach 1 351 4V 4spd Metuchen Built
Re: 1970 Mach 1 AM radio
« Reply #1 on: December 30, 2015, 02:06:15 AM »
You'll need the engineering number rather than the part number of the item to identify it. Paart number would not be stamped on the case.
No 70 radios around the house currently so can't provide that at the moment
Here is a shot of the face of ID purposes
Offline Vcode
« Reply #2 on: December 30, 2015, 08:16:57 AM »
The 70 AM was marked DOZA-18806-A on the side.
It was stamped into the metal case.
Offline palacekeeper
« Reply #3 on: January 31, 2018, 07:43:20 PM »
My radio was swapped out at some point in time. Above the radio that is currently installed, it says "Mustang", which looks like it came that way from the factory, because it looks like it is on the original dash plate. I'm looking at retro style radios to install, and some of them come with the word Mustang at the top, so I wouldn't want it look redundant.
Can anyone confirm whether the word Mustang was there in chrome letters above the radio, originally? I looked at the original Mustang brochure, and the picture does not show the work Mustang, but the picture shows an 8 track version, which mine did not have.
Thanks!
1970 Mustang Mach 1, Grabber Blue
351C 4V M-code, Non A/C
Built at Metuchen
Build Date: December 19, 1969
Dealer: 21A461 Whaley-Dailey Ford Sales, Conyers, GA
« Reply #4 on: January 31, 2018, 11:36:29 PM »
My radio was swapped out at some point in time. Above the radio that is currently installed, it says "Mustang", which looks like it came that way from the factory, because it looks like it is on the original dash plate. ..............................
The radio should have a stamping int he case on the drivers side to help identify when it was made and or the engineering number identifying the application. Can't find any examples (have about 30 examples) without the Philco  for a AM radio in 70.
Offline cobrajet_carl
« Reply #5 on: February 01, 2018, 10:02:01 AM »
Thanks!
If no radio was ordered the bezel had MUSTANG in chrome where the radio would have been. Although I don't see how the MUSTANG could be saved if it was cut for an aftermarket radio.
« Last Edit: February 01, 2018, 03:54:30 PM by cobrajet_carl »
Carl
70 and 71 Dearborn mach Is
Offline 69GT350H
« Reply #6 on: February 01, 2018, 12:00:25 PM »
Thanks!
I found these images on the Tachman's site, dont recall seeing them in any cars:
Offline 427hunter
« Reply #7 on: February 01, 2018, 02:39:29 PM »
That's a 1970 radio for a multi speaker mustang. The multi speaker system has door speakers and is not often seen.
« Reply #8 on: February 01, 2018, 02:43:54 PM »
Have a number of original cars with that radio. But its an AMFM  rather than the one being discussed and apparently Philco produced them with MUSTANG on the face. Don't know why since it they had stayed with Philco and not Mustang then they would nto have had to make different faces for Cougar and Mustang but it was a premium up grade so maybe they thought differently
« Reply #9 on: February 01, 2018, 03:34:00 PM »
Factory 1970 Philco AM Mustang and Cougar radio.
Offline 1970 Snake
« Reply #10 on: February 03, 2018, 07:14:21 PM »
If this is any help for clarity I would like to add a few pics of the original AM radio I pulled out of my 1970 Dearborn built Mach 1. As you can see it has a 1969 C9ZA number and not the 1970 DOZA number. The car was built on Sept 4, 1969.
Dearborn Built Sept 4, 1969
1970 Mach1 428 CJ R-Code C6
dash tach, front bumperettes
