Author Topic: WE NEED HELP TO IDENTIFY THIS BLOCK PLEASE.  (Read 5114 times)
Offline 69cobrajetrugae2
« on: December 25, 2015, 07:49:07 AM »
A friend is looking at a 68 Mustang and sent me this picture of a block stamp located to the rear of the intake on a pad.  I can't make any sense out of it. Any assistance would be greatly appreciated. Thank you.
Re: WE NEED HELP TO IDENTIFY THIS BLOCK PLEASE.
« Reply #1 on: December 25, 2015, 08:21:49 AM »
302? 351W?  Could use a bit more pictures or info.
« Reply #2 on: December 25, 2015, 09:43:02 AM »
Ok, here is the intake manifold. There is a 4BB 4100 on the intake. He was told there is a "302" raised number under the valve cover. This is all I have at this time. I can try to get more information later if need be. Thanks!
« Reply #3 on: December 25, 2015, 10:08:38 AM »
I am not sure but I think it is a 302 out of a Torino. The K was a assembly plant for Torino's maybe in Kansas City.
Marty
« Reply #4 on: December 25, 2015, 11:02:22 AM »
I was thinking the 1K could be November 1971?
« Reply #5 on: December 25, 2015, 11:17:17 AM »
i believe that is a partial vin. no date codes in it. the last 6 digits are the serial #. marti auto works can tell you more about it.
« Reply #6 on: December 25, 2015, 11:52:30 AM »
You ask us to identify the block, then give images of the intake manifold. Though in one image, there is what looks a lot like an aluminum engine tag, which may or may not match the block itself, it would be a whole lot more help to see a final assembly date from the front of the engine (near timing cover at head gasket machined boss) and a casting date of the block with casting number (near starter area)
See if you can obtain any of those images or characters from those locations.
Offline JKWilson
« Reply #7 on: December 25, 2015, 11:57:58 AM »
It appears the engine is a hodge podge of parts based on your photos. The intake is a 66-67 289 4v manifold. The carb is off of a '64 390 with 4 speed. If there's a "302" casting in the valley of the heads, then generally they're 302 heads, though WHICH 302 heads they are would be in question. Based on your photos there's no way to tell what block it is.
« Reply #8 on: December 25, 2015, 12:05:50 PM »
Yes, I believe the last 6 is the sequential number of cars built. We we're hoping that somebody might be able to extrapolate what the block is by the sequential number or recognize the typeset. The typeset does look too crisp for a vintage Mustang era engine block!  We know that the starter has to be removed or otherwise get down and dirty to find the casting numbers, but that is impractical at this time. I took a picture of the engine tag but can't find it, I'll keep looking. If I remember, the tag said 289, Canada, c code, which didn't match the heads or intake or carb. I'll try and get more information, I think there is a video but again, I 'm looking for it. Thanks guys, I'll be back shortly. All of you are great to help us, we appreciate your efforts.
« Last Edit: December 25, 2015, 12:11:00 PM by 69cobrajetrugae2 »
« Reply #9 on: December 25, 2015, 12:35:15 PM »
Okay, I have these of the valve cover area, sorry that we can't be of more help.
Offline Coralsnake
« Reply #10 on: December 25, 2015, 02:56:36 PM »
1 is the year as in 1971
K is the assembly plant
That is called a derivative VIN ( vin w/o body and engine code )
« Last Edit: December 25, 2015, 02:59:12 PM by Coralsnake »
« Reply #11 on: December 25, 2015, 04:19:48 PM »
Thank you all. I'll get more information off the engine next week.
 I read that the 302 heads came with a rocker style in 68 that other years did not use. I am confused as to what the difference is. Something about the stud or rail that other years did not use.
Offline JKWilson
« Reply #12 on: December 25, 2015, 07:19:09 PM »
The heads in the pics are '69 302 heads. The casting date code (9A30), in the second picture shows it was either a '69 or '79 head. Without a casting code it needs to be narrowed further. Since the '79 heads used stamped steel rockers, that narrows them back to '69 heads. Obviously the "302" casting shows them to indeed be 302 heads. The issue with the rockers you're referring to concerns the style of rocker arms and how they're attached. From '68 until the late 70's the heads used a cast rocker arm with a stud in the head. After that they used a stamped steel rocker that was held with a bolt. There are some other nuances with the stud equipped heads, but not worth going into great detail for this explanation.
Since the intake won't fit on a 351W, your block will be either a 289 block or a 302. I'm willing to bet a 302. That's only a guess though that can't be substantiated without any other block info.
« Reply #13 on: December 25, 2015, 07:48:14 PM »
A cording to Corral Snake the 71 date code would make it a 302, there were no more 289s after 68.
Offline 70cj428
« Reply #14 on: December 25, 2015, 08:41:02 PM »
My guess on the block ... A 302 out of a 1971 midsize mercury built at Kansas City
The Carb... an Autolite 4100 off a 1964 390 police car
The intake and heads, as mentioned above (67 289 4V intake, 69 302 heads)
Sounds like a common, pieced together small block.
(Google is your friend  ;)  )
JMHO, John
« Last Edit: December 25, 2015, 08:52:07 PM by 70cj428 »
