Author Topic: 69 Shocks  (Read 3645 times)
Offline Brian Conway
69 Shocks
« on: December 20, 2015, 08:45:22 PM »
The build sheet for my car under SHOCKS, line E, calls out ORANGE.  Does that indicate KONI's or something else ?   Metuchen, Sept. 19,1968 and Mach 1.  Thanks, Brian
5RO9A GT  4 Spd Built 5/29/65
9TO2R SCJ 4 Spd Built 9/19/68
Owner Driver Mechanic
San Diego, Ca.
Offline Vcode
Re: 69 Shocks
« Reply #1 on: December 20, 2015, 09:10:57 PM »
The shocks were black with a spot of orange paint I think.
I think he orange spot was what the production line knew what shocks to use.
Re: 69 Shocks
« Reply #2 on: December 20, 2015, 10:44:15 PM »
Thank you Dale.  I thought the OE shocks were black.  Brian
San Diego, Ca.
Re: 69 Shocks
« Reply #3 on: December 21, 2015, 01:54:23 AM »
The buildsheet was the guide fro workers on the line to build the car. The items listed on the buildsheet were coded by letters, numbers, part numbers (shortened) and colors so that the worker could pick out the correct part for the particular car to speed up production. The codes, letters and numbers were labled on the bins for quick identification of those parts while the color coding made those parts (sometimes in racks or other holders) made that quicker
The Orange was just a simple somewhat small paint daub applied to the bottom end of the shock for that application. The rest of the shock would have been semi-gloss black as mentioned in many other threads here on the site
Guess your front shock on the buildsheet might be marked with white
Re: 69 Shocks
« Reply #4 on: December 21, 2015, 10:24:08 AM »
Si blanco.  Brian
San Diego, Ca.
Offline 13Outlaw
Re: 69 Shocks
« Reply #5 on: December 27, 2015, 04:39:18 PM »
Would this be the same for a Jan 69 Dearborn built R car? Thanks
1969 Mach 1 R-Code 4-Speed (Dearborn built Jan 69)
1992 GT 5.0 5-Speed
2003 Cobra
2013 Shelby GT500
Re: 69 Shocks
« Reply #6 on: December 27, 2015, 05:02:19 PM »
Don''t know - would need to know what transmission your  car has.
Just as a suggestion you might want to include the basic info about your car in your signature (you'll see examples in other peoples postings) so that you don't have to type it each time you ask a question ;)
Offline 13Outlaw
Re: 69 Shocks
« Reply #7 on: December 27, 2015, 05:23:00 PM »
Ok will add in my Sig. It's a pretty low option 69 Mach R-Code. It is a 4-Speed car trans code 6 as I'm sure you know. It also shows it as an option which is strange to me...
1992 GT 5.0 5-Speed
2003 Cobra
2013 Shelby GT500
Re: 69 Shocks
« Reply #8 on: December 27, 2015, 05:26:36 PM »
Rear shock marking of orange would be correct/normal for a 1969  4 speed 428CJ equipped car.
Offline 13Outlaw
Re: 69 Shocks
« Reply #9 on: December 27, 2015, 06:17:31 PM »
Thanks again!
1992 GT 5.0 5-Speed
2003 Cobra
2013 Shelby GT500
Re: 69 Shocks
« Reply #10 on: December 28, 2015, 10:21:21 AM »
close ratio 4-speed trans option isn't strange since 5 wide ratio is standard
Offline 13Outlaw
Re: 69 Shocks
« Reply #11 on: December 28, 2015, 06:34:41 PM »
Ok cool, I just figured since it said the same thing in the boxes area above it was standard as well. Thanks for the info... Anyone have a close ratio late 68 year 4 speed for sell  :)
1992 GT 5.0 5-Speed
2003 Cobra
2013 Shelby GT500
Offline mic-chris
Re: 69 Shocks
« Reply #12 on: January 18, 2016, 10:30:50 PM »
what about 69 428CJ automatic ?  white daub?
Black on Black 1969 Mach1 428CJ auto. built 11/68.
Re: 69 Shocks
« Reply #13 on: January 19, 2016, 02:11:10 AM »
No white would be front shocks. Rear for automatic marking was violet. For full year from what I can tell this moment but it would really help if I knew when your car was built ;)
Offline mic-chris
Re: 69 Shocks
« Reply #14 on: January 19, 2016, 09:31:50 PM »
thanks Jeff.  I put the build date in my signature:)
