Author Topic: 1968 convertible Fog light switch location?  (Read 1600 times)
Offline fastfret7
« on: December 17, 2015, 03:30:56 PM »
Where exactly does the fog light switch go when you have a powered top control? Thanks
Offline Oz390
Re: 1968 convertible Fog light switch location?
« Reply #1 on: December 18, 2015, 02:58:11 AM »
Here is where they are in mine (the mounting bolts are not correct).  Top switch is in original location AFAIK, I added fogs and there are pre-punched holes in the dash for both brackets.
The FAM is not really clear and also notes position will vary if tilt-away is used (mine is standard fixed column)
« Last Edit: December 18, 2015, 03:02:23 AM by Oz390 »
8R03S : 76A I 2A 15M 72 5 U
