Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
Login with username, password and session length
News:
Join us on Facebook: Search for 'ConcoursMustang' Private group!
Home
Help
Login
Register
ConcoursMustang Forums
1st Generation 1964 1/2 - 1973 - Questions & general discussions that apply to a specific year
1970 Mustang
Topic:
1970 hurst shift handle set screw
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: 1970 hurst shift handle set screw (Read 1256 times)
Wills70
Full Member
on:
December 06, 2015, 11:17:28 AM »
Hi, I'm looking for specs on the set screw hole as I need to add this to mine. I'm needing the set screw diameter or size of the allen wrench that fits the screw and the diameter AND depth of the relief hole leading up to the threads. If someone could put the blunt end of a drill in the hole to size this AND get the depth of relief would be a great help.
Thanks Will
Logged
specialed
Hero Member
Re: 1970 hurst shift handle set screw
Reply #1 on:
December 07, 2015, 10:35:51 AM »
don't they make that knob already drilled as that isn't going to be easy to do to get that angle for hole correct.
Logged
Vcode
Full Member
Reply #2 on:
December 07, 2015, 01:11:13 PM »
Semo's sells them.
http://www.semomustang.com/store.aspx?panel=3&productid=699&categoryid=257
Logged
Wills70
Full Member
Reply #3 on:
December 07, 2015, 08:40:10 PM »
I am a machinist by trade and run a high speed vertical machining center and program with CAD software, so putting the hole in is not a problem, I already have this handle so just need a few specs
Thanks Will
Logged
dieseldave
Newbie
Reply #4 on:
December 28, 2015, 12:35:24 AM »
Will, using a machinest square measure back from the front of the handle on the right (passenger side) .520" and scribe a line. Measure up from the bottom .475" and scribe a line. Drill there with a #7 drill (13/64th) through to the 3/8th hole. Follow that drilling with a 23/64th 1.025" deep. Use a 1/4" x 20 NC tap for the set screw. My set screw is 1/2" long. This should be easy for you.... Dave
Logged
Wills70
Full Member
Reply #5 on:
December 28, 2015, 10:29:19 PM »
Thanks Dave, just what I was looking for!
Logged
Print
Pages: [
1
Go Up
« previous
next »
1970 Mustang
Topic:
