Author Topic: Unexpected windshield washer nozzle finish  (Read 938 times)
Offline Rick D
« on: December 05, 2015, 05:01:11 PM »
Hi All,
I was cleaning up some nozzles from a May 65 SJ car and ran across something I did not expect.  I used Blue Magic metal polish pretty lightly to clean 50 years of dirt and grime expecting to see a zinc coating.  What I found instead appears to be copper.  I'm not sure if that is the original surface or if my metal polish removed the silver color and left the next layer under.  Any ideas?  I did a search on this site and on line but can find no reference to a copper finish.  If you look at the attached picture you can see the color and also a very interesting twist at the nozzle tip.  I had not seen that twist before either.
Thanks.
66 GT Convertible, A code (3rd owner)
San Jose built, Sacramento raised until 97
Body 76B, Color T, Int F3, Date 13A, DSO 72, Axle A, Trans 5
65 GT Coupe, A Code (in progress)
San Jose built (Saved from TX junkyard)
Body 65B, Color D, Int 67, Date 05S, DSO 72, Axle 1, Trans 6  (white top, A/C, PS)
Offline Richard P.
Re: Unexpected windshield washer nozzle finish
« Reply #1 on: December 05, 2015, 07:40:05 PM »
I believe the metal polish removed your zinc plating.
« Reply #2 on: December 05, 2015, 07:57:24 PM »
Agree, the zinc plating would have been over the copper.
