Author Topic: Non reproduced wire harness  (Read 2088 times)
Offline preaction
« on: December 05, 2015, 12:05:29 PM »
Is there anyone that can reproduce a big or small wire harness that is not reproduced ?
Offline BobV
Re: Non reproduced wire harness
« Reply #1 on: December 05, 2015, 12:54:54 PM »
Probably depends on what it is, but a good place to start would be: http://midlife66.com/harnesses/welcome.html
1986 Saleen Mustang
51k miles 98% original
« Reply #2 on: December 05, 2015, 12:56:03 PM »
It is not really possible to reproduce one without an original to copy from.  Having an original, in "good enough" shape, it the first hurdle.  The second hurdle is the tooling to create the various connectors.
Bob (19667Bob) has used a company called Class-Tech with, from what I recall, good success.  They appear to have the molds, tools, supplies, and capabilities to get it done.
Offline preaction
« Reply #3 on: December 05, 2015, 06:31:20 PM »
Thanks, I did look at midlife66 and if im correct he cant create a new lets say engine gauge harness. I do have a complete original to copy though.
« Reply #4 on: December 05, 2015, 08:47:49 PM »
Yes, that's quite true: I do not have the machines that mold trailer bullet connectors.  I can craft up pretty much anything recycling Ford products but for something like an engine gauge harness that is exposed for all to see requires a visually perfect harness.  I've had a few customers for these types of harnesses and I strongly discourage going this route.
For those of you who want something fabricated that is not available and is not readily visible, I'm your man!  I've crafted up convenience harnesses (67/68), map and clock harnesses, and even (gasp!) aftermarket dash cluster wiring.
Offline preaction
« Reply #5 on: December 05, 2015, 09:11:17 PM »
Hi Midlife, I did look at your service first as I believe anyone here with a service can not only be trusted but deserves our patronage for the help you and others give freely of yourselves to further our hobby. Is there anyone out there who can make 1 or 2 offs of a harness?
« Reply #6 on: December 05, 2015, 09:55:13 PM »
Give Class-Tech a call.  Won't hurt to ask.
Class-Tech Corp
 62935 Layton Ave.
 Bend, Oregon 97701
 800-874-9981
(541)389-6339
« Reply #7 on: December 06, 2015, 02:56:49 AM »
Part of the challenge ( a detail missing on the current reproductions) is the intersection plastic/rubber blocks that are found on the longer/larger original looms
