Author Topic: Lower dash and A/C vent question  (Read 1227 times)
Offline bjf1992
« on: December 04, 2015, 11:06:39 PM »
Were the lower dash and A/C vents perfectly matching colors? I have repainted the lower dash with the correct factory light blue paint. I am in the process of replacing the felt in the A/C vents. The original paint in the vent portion is perfect. I'd like to just keep it that way. The colors look very close but not exact. I'm assuming this will actually look more correct than painting them with the same can to match 100%. Thoughts??
1969 Q Code Standard Cougar Convertible P/S, P/B, A/C
Pastel Grey, Lt. Blue interior Black Top
Built April 2nd, Dearborn
1969 Mustang Sportsroof
September 68 Build date, Metuchen
Re: Lower dash and A/C vent question
« Reply #1 on: December 05, 2015, 07:43:34 PM »
Do you happen to be doing a Cougar?
The lower dash and the lower AC surrounds, both being Dark Charcoal Metallic on a 69-70 Mustang with blue interior should be a pretty close match IMHO
Here is a few examples of the area on original cars.
Offline bjf1992
« Reply #2 on: December 06, 2015, 04:06:29 PM »
I'm doing a cougar.
« Reply #3 on: December 06, 2015, 04:32:08 PM »
I'm doing a cougar.
Though that might be the answer - though we do see Mustang owners from time to time mess this one up since you don't see many that were not black inside ;)
In your case - basically the same answer. The cups are the same color as the lower metal dash section. Just paint them with the same paint if you have some after prepping the plastic
Offline bjf1992
« Reply #4 on: December 06, 2015, 10:13:43 PM »
Went ahead and painted them!
