Author Topic: 65 Dearborn GT Convt Front and rear valence & front stone guard paint  (Read 2218 times)
Offline 1965 t5
I was reviewing a few older posts online I found and wanted to get this right since my car is in for paint now.  CAn anyone confirm for me the following:
I have conflicting stories about the rear valence.  Was it sprayed on or off the car?  I believed that the backside was just dusted from the spray upwards from the bottom.  Is this right?
Front valence and stone guard - I know these were off the car, but do they get much paint on the backsides?  If so, was the spray on the backside from any specific direction to get heavier coverage?
Headlight buckets and doors - same here
Thank you everyone - this is proving to be a tedious process getting the detail as right as possible.  Almost there and should be final sprayed before the holiday.
« Last Edit: December 11, 2015, 07:55:23 AM by carlite65 »
Re: 65 Dearborn GT Convt Front and rear valence & front stone gaurd paint
« Reply #1 on: December 05, 2015, 08:14:38 PM »
They were painted on the car. How they were attached depended on where the car was built. Two or all (depending on plant) of the top edge attachment screws will be painted body color
Here is an example of the exterior paint shadow that was produced on the rear lower taillight panel documenting that the valance was in place when the car was painted but not on the car when the light grey primer surfacer was applied like we typically find (most periods and plants) behind the quarter panel extentions/end caps
From original examples the amount of "overspray" on the rear side depended on the painter.
For the front valance -  Could be a little (chalky finish with light visible overspray) to much more and nicer looking. The painter should have attempted to insure that the surface where the valance to the fender would attach would not show a thinning of the paint would have produced direct coverage along and directly behind those surfaces . Pretty much the effects we find on the back side of front fenders
Though , from another year, this front valance provides one example of how much color you can find on the back side of an original paint valance.
For the stone guard I've found that normally its a light misting of overspray with a heavier build up along the "bump" that stands out if you roll it over and look at it from the back edge. Appears that this can be produced from the painting of that back edge and the paint flowing (what misses that thin lip) forward onto that lower surface
Where the rust is would have been a red oxide and thin amount of overspray. Unfortunately there was not enough paint to protect the surface on this example given the conditions this car has seen. Rusty area was not bare steel originally ;)
Since they didn't want to run the risk of having no paint along the sharp edges showing once the parts were assembled the overspray tends to be greater IMHO
Offline 1965 t5
« Reply #2 on: December 11, 2015, 01:15:38 AM »
Thank you for all the detail Jeff.  Can you clarify for me that eventhough the front and rear valence were last primed with the grey primer, the stone guard would have been red oxide?  Mine is a Jan 65 car from Dearborn.  Thank you!
« Reply #3 on: December 11, 2015, 01:22:39 AM »
Lots of details and always the possibility of them getting crossed.
Don't know that the front and rear valances were sprayed with the lighter grey primer during the 65-6 period like the unibody was. I would expect that any primer I could find (around, under .... if at all visible) would be the red oxide
Hope this clarifies things
Offline jtfx6552
Re: 65 Dearborn GT Convt Front and rear valence & front stone guard paint
« Reply #4 on: December 24, 2015, 12:37:36 PM »
Here's my thread on the subject, October 29 1964 build dearborn car
http://www.concoursmustang.com/forum/index.php?topic=10078.msg59796;topicseen#msg59796
