Author Topic: C4 Vacuum Line  (Read 647 times)
Offline suskeenwiske
  • 214-347-3628
C4 Vacuum Line
« on: November 29, 2015, 09:23:42 PM »
I have a '65 Dearborn Coupe, 6 Cylinder with Power Brakes, A/C & PS that has an estimated Build Date mid-January 1965. The car came with two Vacuum Lines. The shorter one bolts to the top of the Bell Housing terminating shortly after the Bracket; a Vacuum Hose from there to the Intake Manifold would be needed, and the other terminates with a Fitting that threads into a Brass Tee on the Intake Manifold.
Which one is correct for this application?
Thanks...Ray
Ray
1965 Dearborn Coupe
6 Cylinder, AT, PB, PS, AC
Est. Build 23A
