Author Topic: quarter window regulators  (Read 2361 times)
Offline Sunlitgold68
« on: May 26, 2010, 10:25:50 AM »
Is there a part # on the quarter window regulators? Are 68 regulators different from 67's? Thanks
8T01C204XXX
Built May 14th, 1968
Offline gtamustang
  • CPM
Re: quarter window regulators
« Reply #1 on: May 26, 2010, 04:43:27 PM »
67 and 68 quarter window regulators are interchangeable. I have not seen a part number on the regulators.
Regards,
Pete Morgan
Window regulators
« Reply #2 on: May 27, 2010, 08:31:42 AM »
Can window regulators be "tightened" up? My window would drop an inch or 2 from driving around ect. Use to pull up one window by hand while cranking it. Not sure if this was from lack of grease or wore out rollers or wore out regulators.
8T01C204XXX
Offline gtamustang
  • CPM
« Reply #3 on: May 27, 2010, 02:51:55 PM »
Not really. It sounds like the gear drive mechanism is wearing out for your. There are "adjustments" that can be made to correct most window movement issues...track and guide cleaning, track alignment, stop adjustment, etc.
Regards,
Pete Morgan
« Reply #4 on: May 28, 2010, 08:34:47 AM »
Are rollers normally replaced? If so are the reproductions any good? Thanks
8T01C204XXX
Offline gtamustang
  • CPM
« Reply #5 on: May 28, 2010, 11:31:55 AM »
Rollers that are held on with the spring clips can be replaced. The rollers that are riveted in place are very hard to replace. Typically, I replace the spring clipped rollers that are buggered up.  I usually find good originals to replace with.
Regards,
Pete Morgan
Offline Twilight65
  • Gold Level Subscriber
« Reply #6 on: May 29, 2010, 09:27:31 AM »
Don't know if a 66 is the same as a 67 but my buddy kept having the same problem with his quarter window dropping or slipping. Come to find out someone at one time had removed the roll up stop so when he rolled up the window the gear would go to far on the mechanism and would fall or come out of the track all the time. We put a stop on it and no problem since.
Dave
