Author Topic: Front Shock To Tower Bolts, 67-70 -  (Read 3087 times)
« on: November 24, 2015, 12:26:28 AM »
There appears to be two different types of external tooth lock washers included as part of the bolt, used to mount the front shocks to the tower. The bolt is 42760-S8, as indicated on the 67-70 chassis manuals. The question is based on seeing a 9 tooth lock washer and a 12 tooth lock washer. The have the same head marking, an anchor (same manufacturer) but the teeth are a of a different design as well as count.
The questions are:
- is this a plant particular difference;
- is this a year difference, 67-68 vs 69-70.
Re: Front Shock To Tower Bolts, 67-70 -
« Reply #1 on: December 02, 2015, 07:07:50 PM »
Not sure if you can figure out the number of teeth from a picture but will post a bunch for you to get a start with your research.  Put them all to the side a few days ago but you hadn't a thread to start collecting data for and didn't want to post them to the NJ 69 discussion
« Reply #2 on: December 02, 2015, 07:41:10 PM »
Dearborn scheduled date June 19, 1969 Mach 1 SCJ.  Hard to make out but maybe able to extrapolate ?  Brian
« Reply #3 on: December 03, 2015, 10:02:27 PM »
OK first submission - 69 San Jose examples in sequential order
Sorry their not clearer but the were clipped from larger area pictures I have on file
9R1080xx
9R1102xx
9R1115xx
9R1135xx
9R1200x
9R12436xx
9R135xxx
9R1359xx
9R1757xx
« Reply #4 on: December 04, 2015, 12:34:36 PM »
9R1080xx
9R1102xx
9R1115xx
9R1135xx
9R1200x
9R12436xx
9R135xxx
9R1359xx
9R1757xx
I see 3 different styles of nuts used in the pictures.
« Reply #5 on: December 04, 2015, 04:36:25 PM »
Though the focus is the shock bolts I see two styles (the head details are difficult to see on some examples) of retaining nuts ;)
Different style of forming the nut to make it a self locking nut it appears
Almost appears earlier and later (after the #9R1135 car)
Will have to see what the other plants have to offer. Will keep it to 69 for the first rounds
« Reply #6 on: December 04, 2015, 04:52:25 PM »
  I know the emphases was on the shock bolt but couldn't help noticing the difference in the shock bracket nuts. I saw the typical tall flat top nut like the typical Dearborn style ,  a taller version of the rounded top nut  and a shorter version of the rounded top nut. I am very surprised at the variety of examples for one year (69) at SJ plant. I have never studied the 69 build at SJ so don't know if this is normal or not.
Offline WT8095
  • Dave Z.
« Reply #7 on: December 04, 2015, 06:40:37 PM »
FYI two of the photos are duplicates, with a minor difference in cropping:
9R135xxx
9R1359xx
Dave Z.
« Reply #8 on: December 05, 2015, 07:28:03 PM »
FYI two of the photos are duplicates, with a minor difference in cropping:  9R135xxx   & 9R1359xx
Fixed it thanks
Now the same number of 69 Dearborn examples through the production year
9F02R1124xx
9F02R1137xx
9F02R1227xx
9F02R1230xx
9F02R1365xx
9F02R1561xx
9F02R1588xx
9F02R1826xx
9F02R2169xx
