Author Topic: 68 original seat belt ??  (Read 1634 times)
Offline mhubert89
« on: November 23, 2015, 01:47:32 PM »
hi,
...in a 68 fastback , seat belt are all shoulder belt or you can have only 2 points belt ? in a standar interior what i suppose to have ? how i know wich one was in my car ? how i install the front seat belt with a center console ?
thanks
Mustang Fastback 1968
289, 4 speed
Re: 68 original seat belt ??
« Reply #1 on: November 23, 2015, 06:01:14 PM »
By the time your car was built all cars had the lap and shoulder belts.
Because of this you will have two belts mounted to each side of driveline tunnel on each side. The lap belt normally installed so it can be held in the console cups while the other belt is shoved between the seat and side of the console or flopped rearward behind the seat when not used.
When delivered believe that the shoulder belt belt at the center was folded up and held together neatly, with a thin light brown rubber band
Difficult to see the second belt at the floor mount but its there ;)
Offline mhubert89
« Reply #2 on: November 26, 2015, 09:33:09 AM »
Perfect ! Thanks
289, 4 speed
Offline mhubert89
« Reply #3 on: December 10, 2015, 08:11:32 PM »
I have lots of belts , can anyone told me wich one go where !!
289, 4 speed
« Last Edit: December 10, 2015, 10:36:37 PM by J_Speegle »
« Reply #5 on: December 11, 2015, 12:31:16 AM »
The ones with clear vinyl sleeves are rear seat belts.
Offline mhubert89
« Reply #6 on: December 11, 2015, 11:02:56 AM »
You talk about the 2 shorts one ?
289, 4 speed
« Reply #7 on: December 11, 2015, 02:21:40 PM »
There should be 4 short ones with the sleeves, 2 buckles and 2 hooks.
