Author Topic: need rear backing plates  (Read 1827 times)
Offline Bossman963
« on: November 17, 2015, 12:20:30 PM »
Hi looking for both rear backing plates for a 1970 mustang with 10" x 2"  (boss 302)brakes- let me know condition & cost please ::) :D
thx Mike
« Last Edit: November 17, 2015, 04:07:31 PM by Bossman963 »
2-69 B302 -twins, 1-1970 Cougar Eliminator B302- matching numbers, 70 B302 in progress, 68 Charger, 74 Pantera GTS, 2 fox body Mustangs 1 conv
Re: need rear backing plates
« Reply #1 on: November 17, 2015, 03:11:35 PM »
Probably should specify 10 x 1-3/4 inch or 10 x 2 inch rear brakes. Backing plates are different for those two sizes. Just and FYI.  ;)
Offline Bossman963
« Reply #2 on: November 17, 2015, 04:09:36 PM »
Scott OK and thanks and I assume its 2" as its for a Boss 302 ;)
« Reply #3 on: November 18, 2015, 02:22:29 PM »
Yes, I agree, 2 inch for a Boss.
They would be normally found on 1969-70 9 inch rear ends from Mustang or Cougars. Backing plates have stamped numbers on them identifying right or left, and the various sizes. Two different suppliers, Bendix and Kelsey-Hayes.
Very likely found on other Ford products with a 9 inch rear. Watch out, in the early 1970's they changed design and those won't be compatible.
Below is a cut and paste from Dan at Chocostang
K/H Plates 65-68 Dates are not perfect for 1 3/4"---Numbers are.
70867
70866
K/H for 2"
71086
71087
Bendix Plates 69 and newer for 1 3/4"
319480
319481
Bendix for 2"
317558
317559
« Last Edit: November 18, 2015, 02:31:07 PM by krelboyne »
Offline Bossman963
« Reply #4 on: November 18, 2015, 02:44:20 PM »
thank you for info and my car was built in 10/69
« Reply #5 on: November 18, 2015, 11:32:31 PM »
FYI many times I have seen a Bendix on one side and a KH on the other. They weren't always installed in pairs.Mostly on 69 Dearborn.
