Author Topic: 65-66 Headlamps - Tung Sol and others  (Read 1539 times)
Offline preaction
« on: November 14, 2015, 11:19:05 AM »
Where was the TS located on a headlight?
« Last Edit: November 14, 2015, 10:36:30 PM by J_Speegle »
Re: 65-66 Headlamps - Tung Sol and others
« Reply #1 on: November 14, 2015, 11:51:54 AM »
The TS was located at the bottom middle.
« Last Edit: November 14, 2015, 10:36:40 PM by J_Speegle »
« Reply #2 on: November 14, 2015, 06:12:16 PM »
« Last Edit: November 14, 2015, 10:36:49 PM by J_Speegle »
Offline preaction
« Reply #3 on: November 14, 2015, 08:15:50 PM »
Was general electric used after that ? Also would these bulbs have a date such as 7 A inked on the back ?
« Last Edit: November 14, 2015, 10:37:00 PM by J_Speegle »
Re: Re: Tung Sol Headlamp
« Reply #4 on: November 14, 2015, 09:07:35 PM »
GE was used at the same time. Ford didn't want to depend on one supplier in case of a work stoppage or whatever at the vendor. Date codes ink stamped on the back of the bulb typically . They can come off if back side is washed.
« Reply #5 on: November 14, 2015, 10:32:53 PM »
Think its time to split most of the posts off and put them in the correct discussion section ;)
Believe we've past the "helping the OP" to - teaching and sharing
« Last Edit: November 14, 2015, 10:37:08 PM by J_Speegle »
