Author Topic: 1968 hood turn signal wiring same as 69 ?  (Read 1004 times)
Offline mhubert89
« on: November 13, 2015, 04:28:35 PM »
Hi,
can someone told me if the Hood turn signal wiring are the same for 68 and 69 ?
thanks
Mathieu
Mustang Fastback 1968
289, 4 speed
Re: 1968 hood turn signal wiring same as 69 ?
« Reply #1 on: November 14, 2015, 05:53:49 PM »
Without comparing side by side would think that the 68 version would be much longer in length since they must travel and attach towards the front of the hood and the 69 at the rear.
« Reply #2 on: November 14, 2015, 08:53:29 PM »
Jeff:
The 67/68 headlight harnesses have a two pin plug just forward of the firewall grommet for the hood turn signals.  It appears this was a standard feature.
The 69  headlight harness does not have this two pin plug, but I do remember there is a separate sub-harness that plugs into the turn signal 3 pin plugs and feeds a two pin plug that ends up near the firewall.  The original poster is wondering whether the harness that plugs into that two pin plug is the same for 68 and 69.
« Reply #3 on: November 14, 2015, 10:30:48 PM »
Hmm...
Read "if the Hood turn signal wiring are the same for 68 and 69 ?" and thought he was asking about the wiring
Offline mhubert89
« Reply #4 on: November 15, 2015, 03:36:11 PM »
Hmm...
yeah just talk about the wiring !
289, 4 speed
« Reply #5 on: November 15, 2015, 09:12:24 PM »
My bad :'( ...I misinterpreted what Jeff was talking about: the actual wiring that goes to the hood turn signal lamps vice the entire wiring assembly for the 69's which also pick up the signals at the front of the "hood" area but actually at the front of the car at the radiator support.
And now back to your regularly scheduled programming....
