Author Topic: Parts finish questions.  (Read 1941 times)
1967 eight barrel
  • Guest
« on: November 10, 2015, 03:43:19 PM »
On my 1967 shelby, there are two parts that hold the emergency brake cables. One is what I would call an idler. It is a five inch long piece with hook on each end. One holds the cable, the other goes into the bracket on the floorboard. The second is a threaded bolt with a stamped metal piece that hooks in to the floorboard on one side and the brake cable passes through the other. Should these be zinc or phosphate.
Secondly, the L bracket that the hood latch secures to on the inboard headlamp bracket. Painted black, phosphate or silver zinc?
Your assistance is appreciated.
Re: Parts finish questions.
« Reply #1 on: November 10, 2015, 09:36:46 PM »
The ones I have found were zinc phosphate . It is popular to plate them zinc silver but I believe this to be incorrect from my observations. The "L" bracket you are referring to is that the hood catch for the hood latch? If it is then zinc phosphate.
« Reply #2 on: November 11, 2015, 12:02:08 AM »
That is right Bob the silver zinc E brake arms ones service replacements.
1967 eight barrel
  • Guest
« Reply #3 on: December 07, 2015, 11:18:15 PM »
Thanks, gentlemen. I know the ones I bought from Ford were bright silver, but noticed several OE applications looked gray.
