Author Topic: Gold Cad for seatbelt bolts.  (Read 1944 times)
1967 eight barrel
  • Guest
« on: November 06, 2015, 05:52:05 PM »
Does anyone do it locally, or on an exchange basis?
Re: Gold Cad for seatbelt bolts.
« Reply #1 on: November 06, 2015, 06:24:47 PM »
Maybe . Local is relative,where are you?
« Reply #2 on: November 06, 2015, 10:28:45 PM »
Most areas has someone that does zinc dichromate which I believe will pass inspection :)
« Reply #3 on: November 07, 2015, 08:01:28 AM »
How accurate are the AMK replacements?
« Reply #4 on: November 07, 2015, 02:40:21 PM »
AMK states "similar", they're shorter.
1967 eight barrel
  • Guest
« Reply #5 on: December 08, 2015, 12:37:54 AM »
The issue is that it's a Shelby. They don't use the standard Mustang seat belt bolts. They use the longer shank bolts. They are the same as vehicles with the factory shoulder strap option. They use the same spacer as well between the shoulder harness and the buckle/retractor as well.
