Author Topic: Wanted 68 steering column brackets  (Read 881 times)
Offline 1965GTFB
« on: November 01, 2015, 11:40:20 PM »
**Update**  Found some.
Need the brackets circled in Blue and Green.  I already have the one circled in Red.
Feel free to email directly nelsons565@yahoo.com
« Last Edit: November 02, 2015, 07:10:49 PM by 1965GTFB »
Re: Wanted 68 steering column brackets
« Reply #1 on: November 02, 2015, 06:35:20 AM »
Yeah, you would have a difficult time installing a 68 column into a 67 withouth these things ;)
I did the conversion so many years ago (circa 1979) on a car I sold in 1981, so I couldn't tell you details of what I had done without seeing a picture again. As I mentioned in the other thread, I used a tilt column from a Cougar for that job except I didn't install the tilt-away parts/pieces, just the column and gear box with connecting pieces.
It is possible the wiring connections can differ a little from 67 to 68, you might check into this.
Offline 1965GTFB
« Reply #2 on: November 02, 2015, 07:12:51 PM »
The 67 turn signal switch actually worked fine in the 68 column.  Save all the slice and dice required to blend the 68 switch to the 67 harness.
Found the brackets this morning from West Coast Cougar.
Thanks for the input.
