Author Topic: 67 Mustang S code LW horn / with AC  (Read 2871 times)
Offline Horace Collums
« on: May 23, 2010, 02:34:35 PM »
Does any one have a picture of a LW drivers side horn,  my car has factory AC.  I Have  several LW horns they don't looks wright.  Thanks
Horace
67 pink S code Mustang
Re: 67 Mustang S code LW horn / with AC
« Reply #1 on: May 26, 2010, 12:15:00 AM »
Here is some examples - hope they help
Examples from 7R0xx133,000-188,000
« Reply #2 on: May 26, 2010, 12:49:11 AM »
Thanks Jeff that's helps  I was mounting the horn in the wrong holes also.  This helps a lot.
Horace
« Reply #3 on: May 27, 2010, 09:32:00 PM »
Jeff thanks again for the picture,  I was able to locate a 67 low AC horn with the wide mounting bracket out in CA. it will be in Houston Friday and on the Pink mustang Saturday.
Horace
Offline gwells67
« Reply #4 on: June 18, 2015, 12:30:52 PM »
Hi guys, can you help please?  I am gathering the last few parts I need to install AC on my '67 and I know that the low horn needs to move (and change). I feel like I picked one of these special horns up long ago.  The problem is that when I pulled out my box of spare horns, they all look like this one in these photos.  What does a non-ac horn look like?  It's possible I have like 6 extra A/C low horns--FYI?  What specifically is different on the bracket?
« Reply #5 on: June 18, 2015, 03:05:31 PM »
The bracket is clocked differently on NON Air Conditioned cars for one, and the no AC cars mounted in a different hole, further from the center of the car. The AC horn bolts in as pictured previously. Both horns are pointed downwards when installed I believe.
Richard
« Reply #6 on: June 18, 2015, 06:07:05 PM »
Richard is correct.  To supplement, attached are two pictures.
One shows an AC application, and I've pointed out the holes for a non AC application.
Also I included a non AC horn.
Note the different angle of the bracket.  The AC app comes out of the horn at the 12 o'clock position, and the non AC app is roughly 2 o'clock.  In both cases the horn "discharge" points down at 6 0'clock.
« Reply #7 on: June 18, 2015, 06:27:12 PM »
John's picture #1 also shows clearly the two locating "fingers" on the side of the AC condensor support bracket, the AC condensor shares the same bolt and nut. Another note, non AC horn has only one locating "finger".
« Last Edit: June 18, 2015, 06:29:21 PM by 67gtasanjose »
Offline gwells67
« Reply #8 on: June 20, 2015, 11:38:12 AM »
ahhh..now I get it!
