Author Topic: Brake Drum Spring  (Read 1399 times)
Offline Building 3
Brake Drum Spring
« on: October 29, 2015, 11:12:48 AM »
I have a question on 1966 Mustang Drum Brakes.  I have attached a photo.  I am interested in the red spring below the wheel cylinder.  I have reassembled the brakes using the Ford Shop Manual and with photos of the disassembly. I few people have told me that I should not re-install the red spring.  They said that Ford issued a Service Bulletin to the dealers back in the 1960's saying that the spring was not doing its intended job and that it had a tendency to snap and break and cause all sorts of damage to the brake drum.  Has anyone heard of this? The car has gone 25,000 miles and no problems for 50 years. I think this is only the second brake job that the car has had. Any thoughts? Thanks
Re: Brake Drum Spring
« Reply #1 on: October 29, 2015, 11:15:15 AM »
i have never heard of that bulletin. i have done countless brake jobs and never had a problem with that spring coming off.
Offline Building 3
« Reply #2 on: October 29, 2015, 11:16:45 AM »
289 2V. This is a photo of the rear drum.  The car has power drum brakes all around.
« Reply #3 on: October 29, 2015, 11:17:25 AM »
photo not attached??
Offline Building 3
« Reply #4 on: October 29, 2015, 11:18:59 AM »
The photo should be there now.
« Reply #5 on: October 29, 2015, 11:20:40 AM »
The spring should be there.  I've only seen them blue though, not red.  Pic attached of a '65.  Only thing I believe wrong with this pic is the brake shoe on the back should have a black hold-down spring instead of blue.  (Same applies to rear brakes).  The hold-down washers should be zinc w/dichromate also...
Offline CW4macret
« Reply #6 on: October 30, 2015, 12:57:14 PM »
Agreed spring is needed for proper application of the brakes. I have always installed.
Mac
64.5, 5F07D
66 Convertible 6T08T
71 Mach1 429CJ 1F05J
01 Coupe
05 GT
08 GT500
14 GT500
Offline Building 3
« Reply #7 on: October 31, 2015, 02:04:34 PM »
Thanks for all of the input.  The spring stays. Appreciate the help.
