Author Topic: 67 brake master cylinder  (Read 3601 times)
Offline preaction
« on: October 25, 2015, 10:18:42 PM »
Is there a difference between a master cylinder used on  power, non power and drum/ disk applications.
Re: 67 brake master cylinder
« Reply #1 on: October 25, 2015, 11:55:28 PM »
Yes there are different applications.
« Reply #2 on: October 25, 2015, 11:56:43 PM »
Believe ( if I recall correctly) there is a difference in piston and bore size. Of course disc verses none disc the major visual difference is the size of the fluid bowls.
Offline preaction
« Reply #3 on: October 26, 2015, 06:01:43 PM »
Would a  67 power disk master cylinder have a piston stop also ? Has anyone seen a identification paint stamp such as the letter M on the master cylinder.
« Reply #4 on: October 26, 2015, 11:03:16 PM »
Yes
Not on an original
Offline 67350#1242
« Reply #5 on: January 02, 2016, 04:11:53 PM »
I have seen the letter "M" stamp on original factory  master cylinders.  My original 67 MC has "M" stamped on the end away from the booster.  The 67 shop manual indicates M is for Mustang/Cougar application.   It isn't painted on, however.
Kurt.
67 Coupe SJ 11/16/66
67 GT350 SJ 2/01/67
Offline preaction
« Reply #6 on: March 07, 2016, 09:15:20 PM »
What is the significance of a master cylinder with a small raised bump at the top of the boss for the  front line (front of car) of the master cylinder. I have seen this discussed elsewhere do these come into play with mustangs.
« Reply #7 on: March 07, 2016, 09:28:38 PM »
It is one of the distinguishing features of a assemblyline Master cylinder when discussing a Mustang Master cylinder.
« Reply #8 on: March 08, 2016, 12:15:27 AM »
It's the area where the fluid activated brake light switch was mounted for 64 (and earlier) Fords. It's kind of like the appendix (the medical version) of cars.
Offline preaction
« Reply #9 on: March 08, 2016, 01:25:30 AM »
Would that be for a 67-68 only ?
« Reply #10 on: March 08, 2016, 01:35:25 AM »
+ 69/70.
Offline Anghelrestorations
    • Anghel Restorations
« Reply #11 on: March 10, 2016, 08:20:15 PM »
+71
Marcus Anghel
www.anghelrestorations.com
« Reply #12 on: March 10, 2016, 08:52:32 PM »
+72/73
Offline preaction
« Reply #13 on: June 12, 2018, 09:39:41 PM »
I see that this is a older thread but suprissingly there are not many threads supporting this issue, I found a master cylinder from a 68 power disk equipped car with the correct stop bolt and the cast iron  riser at the front of the master cylinder it also has a few numbers neatly stamped on the side towards the drivers fender, C8075 AT is this common or is it a sign of something other than a assembly line part ?
« Reply #14 on: June 12, 2018, 10:44:44 PM »
I do not find the metal stamped numbers like  C8075 At and sometimes other numbers on all masters. I have taken apart many virgin assemblyline masters that did not have any numbers stamped on the side.  I am not sure what the numbers mean but given they vary and are not on all assemblyline type masters I am skeptical that they are done at Bendix indicating assemblyline.
