Author Topic: 4100 Autolite Carburetor code  (Read 5613 times)
Offline austr6
« on: October 25, 2015, 06:23:50 PM »
Hello, I have a question relating to a carby on my 66 GT A code. It has a code on the base stamped into it that reads  C6AFAA. I cannot determine what this carby was on originally, or if it is the correct carby for my vehicle.
if any one can help that would be great.
Please let me know if you require any more info.
Thank you.
May 20 1966
GT Fastback
A code,
Auto ,Air conditioning, Power Steering
Standard Interior
6R09A202931
Re: 4100 Autolite Carburetor code
« Reply #1 on: October 25, 2015, 06:32:18 PM »
By the numbers posted appears to be a replacement and not original to your car.
Books show a C6AF-A as an original for a full size car's 289 4V carb with a manual trans
« Last Edit: October 25, 2015, 06:34:20 PM by J_Speegle »
« Reply #2 on: October 25, 2015, 08:33:43 PM »
The part number in question and answer don't match. C6AF-AA is a 2100 for a full size Ford, AT and smog. C6AF-A is 2100 for a full size Ford, MT, no smog. Go back and look at the base and ask again.
« Reply #3 on: October 25, 2015, 08:38:10 PM »
The part number in question and answer don't match. C6AF-AA is a 2100 for a full size Ford, AT and smog. C6AF-A is 2100 for a full size Ford, MT, .................
Thanks. Checked again and yes I had the 2100 page rather than the 4100 one :(
That's why the group effort really works :)
Offline austr6
« Reply #4 on: October 25, 2015, 08:45:17 PM »
This carb is a four barrel... I'm very new to ford stuff, but I was of the belief that the 2100 was a two barrel carb?
And what is a full size ford?
Thanks again
May 20 1966
GT Fastback
A code,
Standard Interior
6R09A202931
« Reply #5 on: October 25, 2015, 08:50:52 PM »
LTD and Galaxie would be two examples of full size Fords
Offline austr6
« Reply #6 on: October 25, 2015, 09:31:21 PM »
can someone please then let me know Exactly what carby i should have on my car so i can source the correct one, the vehicle is a 66 GT A code fastback (6R09A202931). DSO  712887 (was a special order paint vehicle, hence long DSO)
I need to know with 100% certainty.
Thankyou
May 20 1966
GT Fastback
A code,
Standard Interior
6R09A202931
« Reply #7 on: October 25, 2015, 09:50:18 PM »
Thankyou
Sure. It should be a C6ZF either a -D for a manual transmission or a -E for an AT. It is determined by transmission. Note the "Z". Your DSO is Los Angeles so you get a smog carburetor, with the appropriate smog stuff. Non-smog are a -A for the MT, and a -B for an AT. The -C and -F are used on 66 and some 67 289 HP engines, plus most of Shelby GT350H's.
For the record, where are you in Australia? You got a lot of "mates" on the forum.
Offline austr6
« Reply #8 on: October 25, 2015, 10:01:30 PM »
im in Adelaide, South Australia   :D
May 20 1966
GT Fastback
A code,
Standard Interior
6R09A202931
Offline outlawincorporated
  • Kangaroo Herder
« Reply #9 on: October 26, 2015, 03:30:18 PM »
austr6.
I am almost certain I have a restored C6ZF-D (manual with Californian smog) and also a unrestored C6ZF-E (automatic with Californian smog) in stock at present.
so both bases are covered, drop me a email; outlaw@hn.ozemail.com.au
and I will send you pictures and information.
regards.
PHILL BERESFORD.
MELBOURNE.
AUSTRALIA.
« Last Edit: October 29, 2015, 02:03:09 AM by outlawincorporated »
Offline austr6
« Reply #10 on: October 26, 2015, 09:07:50 PM »
Thank you Phill, i will record your email details and will be in contact.
One more question, does it absolutely 100% have to be a smog equipped car as there is no evidence of smog equipment ever being fitted to it???
May 20 1966
GT Fastback
A code,
Standard Interior
6R09A202931
Offline Richard P.
« Reply #11 on: October 26, 2015, 09:58:00 PM »
What is your cars DSO? This might help with the smog question.
Offline Richard P.
« Reply #12 on: October 26, 2015, 09:59:33 PM »
Sorry I now see the DSO.
priceless
  • Guest
« Reply #13 on: October 27, 2015, 09:12:52 PM »
austr6.
I am almost certain I have a restored C6ZF-D (manual with Californian smog) and also a unrestored C6ZF-B (automatic with Californian smog) in stock at present.......
According to search and research the C6ZF-B Excluded TE (thermactor Emissions)? Someone here know something different?
Also, what Mustangs received the C6ZF-B carburetors?  A codes?
Offline JKWilson
« Reply #14 on: October 27, 2015, 09:48:25 PM »
I believe the correct code for TE and automatic trans should be C6ZF-E. The C6ZF-B would indeed be for an "A" code car as this denoted a 289-4v car, with an automatic trans (non-TE).
