Author Topic: correct casting numbers for a 428 p.i. block  (Read 2763 times)
Offline kcodecoupe
« on: October 24, 2015, 09:35:13 PM »
What is the correct casting number for a nov/dec 66 428 police interceptor block ,
Offline rockhouse66
Re: correct casting numbers for a 428 p.i. block
« Reply #1 on: October 25, 2015, 10:03:21 AM »
Casting numbers aren't much help on a FE engine but I think it should have an "A" scratch on the rear bulkhead.
'66 GT FB
Offline kcodecoupe
« Reply #2 on: October 25, 2015, 10:19:04 AM »
Would it also have C6AE-B or C6ME-A castings on the block
« Reply #3 on: October 25, 2015, 05:20:25 PM »
Only have record of a couple from that time period and they are -A
Of course there are another 3-4 other engine sizes that will have the same markings :(
Since you report its a 428 PI you've already doe the scratch letter test and measured the bores as well.
Offline kcodecoupe
« Reply #4 on: October 25, 2015, 05:54:29 PM »
I dont have a block to measure bore , im looking for a block for someone and dont have much info on them,
« Reply #5 on: October 25, 2015, 06:29:58 PM »
IMHO can't really trust everything you see on the outside (castings) of a FE block. Ford choose to reuse the exteriors from other engines when making these things so you might (for example) find the back casting the same as a 427 side oiler and the sides from a 352  while the front is from another earlier engine.  Without opening it up an checking other things you could be purchasing a truck block or passenger.
Tread carefully
Offline kcodecoupe
« Reply #6 on: October 25, 2015, 11:07:30 PM »
Tread carefully
Thanks for the heads up on that , im glad i dont need one.
1967 eight barrel
  • Guest
« Reply #7 on: October 27, 2015, 06:08:28 PM »
On my original 428 block, you can only see a straight line scratch, it's not a complete A and the block casting is a C6ME, not C6ME-A. There are no vin numbers on the block. The original heads are a C7AE-A.
