Author Topic: Autolite 4300 ZF-D  (Read 3684 times)
Online ruppstang
Autolite 4300 ZF-D
« on: October 22, 2015, 12:42:10 AM »
Here are some pics of our Autolite 4300  C8 ZF-D. Did we miss any thing?
Marty
Offline Hipo giddyup
Re: Autolite 4300 ZF-D
« Reply #1 on: October 22, 2015, 01:59:17 PM »
Looks pretty good!.. I was lucky enough to snag an early take off C8ZF D carb. I noticed on my carb that there were a few markings though not sure what they were other than maybe QC?? Also, my carb had plastic "limiters" on the mixture screws under the front. I would think they would be "concourse" but let's see how others chime in... I can supply pics if needed.
« Reply #2 on: October 22, 2015, 06:02:13 PM »
Looks great - really like the body color
A few things I see - based on other original and NOS examples
1- fast idle arm and adjusting screw were zinc not dichromate
2- Interesting that your choke body is one piece with the threads in plastic. Have normally seen the bonded (epoxied) brass threads
3- The "valve" between the secondary openings on the ones I have were dichromated. It may just be the angle/photo since it looks gold in the side angle
4- Nut on the anti-stall on mine are zinc
5- The secondary stop "arm" (on the passenger side end of the secondary shaft) is dyed red on some  the NOS ones I've got r had
Now you need to find the plastic limiter caps for the idle/bleed screws ;)
« Last Edit: October 22, 2015, 06:24:28 PM by J_Speegle »
« Reply #3 on: October 22, 2015, 09:37:24 PM »
 Here are some pics of my carburetor. And little dusty and not as clean as Jeff's.  ;)
« Reply #4 on: October 22, 2015, 10:47:50 PM »
Hard to compete with NOS boxed in 68 - 69 :)  but yours doesn't look bad at all
Got to love the new spring retainer/attachment location   ::)
See it has the same choke cover.
Online ruppstang
« Reply #5 on: October 23, 2015, 12:22:03 AM »
The choke cover is a service part. It is hard to find nice originals. Speaking of hard to find anyone have the plastic mixture screw covers?
« Reply #6 on: October 23, 2015, 01:27:42 PM »
 Yeah, purchased the carb from Ebay years back and never touched it.. I was told it was used on the prior owner's 68 J code only for a few months until it was swapped out for a Holley..
Can't say I have seen caps for sale , and I'm sure they are hard to find as they seemed to have gotten tossed early on. I have a set of blue caps , though not sure why there were white and blue caps??? Either way, always good to have an extra set on hand. ;D
« Reply #7 on: October 23, 2015, 01:52:16 PM »
Coincidentally the later Holley replacement caps are blue also .
Offline Murf
« Reply #8 on: October 24, 2015, 11:26:41 AM »
The little plastic limiter  replacement caps used to come with rebuild kits when these and other carbs were still only a year or two old.  The color of the cap indicated that it was a replacement and the carb had been apart.  The originals were a whitish or ivory while the replacements were bright colors and I think they would vary in color by carb kit vendor and carb type.
John Murphy
« Reply #9 on: October 24, 2015, 08:30:20 PM »
I remember my father cursing at those caps when he tried to tune up the carb (I was but a wee lad of 15 or so...).  Can someone explain the purpose of these caps?  I suspect they were anti-tamper hardware to keep the carb in emission control from the factory.  However, they are easily removed and re-installed, no?
« Reply #10 on: October 24, 2015, 08:38:41 PM »
Pretty much - if you want the official explanation sire its in one of my handbooks or articles
Offline WT8095
  • Dave Z.
« Reply #11 on: October 24, 2015, 11:44:41 PM »
Excerpts from the 1968 Vehicle Emission Control Systems - Training Handbook 5000. Specifically states that service caps are colored plastic.
Dave Z.
