Author Topic: Front Edge of Carpet--Where does it go?  (Read 1431 times)
Offline wunderwerks
« on: October 18, 2015, 04:50:36 PM »
Putting the carpet in and haven't found good pictures or reliable sources of where the front edge of the carpet should go.  Has to be one of the following:
1.  Lay over the top of the bottom edge of the firewall pad--if so how far--raw edge of carpet exposed.
2.  Terminate even with the bottom edge of the firewall pad--this could lead to gaping later.
3.  Tuck under the bottom of the firewall pad--could distort the pad a little.
Any advice?
64.5 Cpe. Poppy Red 5F07D 23G
64.5 Conv. Bright Cherry Sparkle 5F08F 16F
65 2 + 2 Caspian Blue 5F09K  23K
Re: Front Edge of Carpet--Where does it go?
« Reply #1 on: October 18, 2015, 05:02:42 PM »
the carpet goes over the firewall pad. the pad was installed first. don't tuck or trim the carpet.
Offline wunderwerks
« Reply #2 on: October 18, 2015, 05:59:47 PM »
Over the pad is where I had done it years ago without any guidance.  When I lined up the transmission opening and back edge where it should be, I had 3 to inches extra on the front edge and just didn't know how much to trim back.  I had to cut about three inches of carpet off under the heater cardboard vent just to get it far enough forward so the back and transmission opening would line up.  I believe if I leave about an inch overlap it should look right I hope.
« Reply #3 on: October 18, 2015, 06:12:51 PM »
Keep in mind that carpets and firewall pads fit a lot better back in the 60's. I don't know what Ford did exactly, but they did have control of their vendors, so "things" fit better.
« Reply #4 on: October 18, 2015, 06:30:40 PM »
Putting the carpet in and haven't found good pictures or reliable sources of where the front edge of the carpet should go. .........
Sorry didn't see the request
Here is one original example of the edge, placement and notches.
On a few examples I've found a larger notch for the gas pedal
Offline wunderwerks
« Reply #5 on: October 18, 2015, 07:24:01 PM »
Jeff,
These pics are perfect.  Twenty and thirty years ago when I put in carpet, I know I didn't have to do this much trimming or else my memory is gone.  Thanks for the accuracy shown in these pictures.  I'll cut a nice even edge on the carpet and lay it in where it is shown.
