Author Topic: Door window frame finish  (Read 4106 times)
Offline sparky65
« on: May 21, 2010, 09:38:44 PM »
What is the finish on the door window frames supposed to be?  Does it even mater can you tell once its installed?
Steve
2009 Black GT Coupe
Offline Sunlitgold68
Re: Door window frame finish
« Reply #1 on: May 21, 2010, 10:28:29 PM »
Vent Windows are chrome.
Door glass is stainless.
8T01C204XXX
Built May 14th, 1968
Offline sparky65
« Reply #2 on: May 21, 2010, 10:54:42 PM »
I knew the trim piece that actually goes around the glass was stainless.  I didn't know the frame itself was.  Mine is very rusty.  So I guess its not something that can be re-plated.
Steve
2009 Black GT Coupe
« Reply #3 on: May 21, 2010, 11:01:38 PM »
Ok, you're talking about the part inside the door, the metal thats under the glass?
I was told to dip in evaporust and paint stainless steel color, that's about all you can do for that.
8T01C204XXX
« Reply #4 on: May 21, 2010, 11:16:25 PM »
They were zinc plated.
« Reply #5 on: May 22, 2010, 12:09:21 AM »
Charles, do you normally replate these pieces?
8T01C204XXX
« Reply #6 on: May 22, 2010, 05:24:02 PM »
I know he did on the current (the K code vert) project
« Reply #7 on: May 22, 2010, 10:17:07 PM »
Yes, normally re-plate them.  Not any problem.
« Reply #8 on: May 22, 2010, 10:53:48 PM »
So the glass just comes off from the metal piece? I haven't looked at mine closely, they are at my storage unit. thanks
8T01C204XXX
« Reply #9 on: May 23, 2010, 01:55:59 AM »
Glass is held in with glass tape, it pulls right out of the bottom frame and also the top stainless frame.
« Reply #10 on: May 24, 2010, 03:10:12 PM »
Charles, do you tone down the zinc like the other parts we discussed.
8T01C204XXX
« Reply #11 on: May 24, 2010, 08:02:32 PM »
The clear zinc usually doesn't need anything.
« Reply #12 on: May 24, 2010, 11:28:18 PM »
My rollers look weak, the rivet part, are they suppose to be riveted in tightly? I can move the rollers around easily.... in several directions.
8T01C204XXX
Offline sparky65
« Reply #13 on: May 24, 2010, 11:50:50 PM »
I was just looking at the ones on my regulators and was wondering the exact opposite.  They seem very tight and they are hard to turn.  I was going to try to soak them since I think they got filed up with grime.  I would think they should spin fairly easily but not be so loose they they can be tilted.
Steve
2009 Black GT Coupe
« Reply #14 on: May 25, 2010, 12:18:10 AM »
This is probably an easy fix.
8T01C204XXX
