Author Topic: Temp sending unit issue  (Read 1493 times)
Offline Rick D
« on: October 16, 2015, 04:38:27 PM »
Was there some type of threaded adapter (sleeve) that was used with a C5DZ-10884-A temp sending unit?  My intake manifold is a 5 April 65 C5OE-C intake which should take that smaller diameter sending unit, I think.  The problem is it is too small and the larger diameter sending unit actually fits fine.  However, the larger ones are not called for until after 9/1/65 so something is wrong.  I have heard that there might have been an adapter or sleeve that was put in the manifold to allow use of the smaller diameter unit.  All my previous experience has been with 66 manifolds so I'm not sure.  Can anyone shed light on this?  Thank you.
66 GT Convertible, A code (3rd owner)
San Jose built, Sacramento raised until 97
Body 76B, Color T, Int F3, Date 13A, DSO 72, Axle A, Trans 5
65 GT Coupe, A Code (in progress)
San Jose built (Saved from TX junkyard)
Body 65B, Color D, Int 67, Date 05S, DSO 72, Axle 1, Trans 6  (white top, A/C, PS)
Offline lancelot66
Re: Temp sending unit issue
« Reply #1 on: October 16, 2015, 04:52:07 PM »
Yep, there is an adapter you can use for that to reduce the size to accommodate the smaller/earlier sending unit. I don't have access right now to my book, but here's a reference to it for you (from Bob Mannel's wonderful book):
http://www.team.net/html/tigers/2006-09/msg00024.html
VR/
-Lance
SJ Build Date: 1/6
Many Original Options
Offline lancelot66
« Reply #2 on: October 16, 2015, 05:12:49 PM »
You can try typing this into Google Search too, for pictures and sourcing info:
3/8 to 1/8 npt reducer
VR/
-Lance
SJ Build Date: 1/6
« Reply #3 on: October 16, 2015, 05:33:02 PM »
I have some new adapters.  Send me a PM if interested.
« Reply #4 on: October 16, 2015, 06:20:03 PM »
Picture of the set up on my May 65 car.  Brian
Offline Rick D
« Reply #5 on: October 16, 2015, 07:13:07 PM »
Thanks for your help everyone!
