Author Topic: '67 deluxe interior dash "knee pad" removal/installation  (Read 1230 times)
Offline socalgt
« on: October 12, 2015, 11:33:16 PM »
Any suggestions for removing as few trim items from the dash as possible in order to remove/install the "knee pad" on the dash?  (The car has a/c)  The glove box and the radio are currently not installed, so I was able to get a few off nuts without too much effort.
        Thanks....
« Last Edit: October 13, 2015, 01:30:49 AM by socalgt »
Re: '67 deluxe interior dash "knee pad" removal/installation
« Reply #1 on: October 13, 2015, 06:32:07 AM »
Try removing the flex duct going to the right side AC outlet. After that, the correct length socket, extension combination should get you onto each of them. It helps to know where they are, one above right side of the ash tray opening (should be accessible through the radio opening) one centered above the radio and three centered above the glove box opening for a total of 5 nuts.
« Last Edit: October 13, 2015, 05:38:50 PM by 67gtasanjose »
Offline socalgt
« Reply #2 on: October 13, 2015, 05:10:33 PM »
Sounds good....looks like the one under the center duct will be the hard one to get....and maybe the one that is above the ash tray.
        Thanks...
