Author Topic: Drop off holes  (Read 2293 times)
Offline ng8264723
Drop off holes
« on: October 07, 2015, 09:17:02 PM »
My car had the drop offs replaced.  Does anyone have a diagram for the correct placement of the factory drains?
Re: Drop off holes
« Reply #1 on: October 07, 2015, 09:46:17 PM »
what are you working on?? need more info please.
Re: Drop off holes
« Reply #2 on: October 08, 2015, 12:04:33 AM »
No diagrams or measurements - just pictures.
Two holes - one larger round with a small square hole above that - each side
One with the drain in place
One with it out showing the holes - sorry metal is a little deformed but best picture showing an unaltered or rusted out set of holes
Offline ng8264723
Re: Drop off holes
« Reply #3 on: October 08, 2015, 02:22:49 PM »
1970Mustang SCJ
How do you make the holes?  Size etc?  I would think drill the bottom with a hole saw or use a green lee punch?  The top drill a hole then file until square?
Re: Drop off holes
« Reply #4 on: October 08, 2015, 04:51:07 PM »
1970Mustang SCJ
One way to get a similar non jagged square edge is with a electricians hole punch ,chassis punch ? I think it is called . in any event a electricians  tool. I believe it is used for electrical boxes,panels,etc.  Two halves that bolt together and fit inside each other to shear the metal and leave a smoother edge unlike a hole saw.
Re: Drop off holes
« Reply #5 on: October 08, 2015, 06:46:49 PM »
If the panel is not mounted on the car yet, an "ironworker" (various makes/models) is the way to go, one example attached.  I've got one at work, with a plethora of die shapes and sizes.  You certainly won't be spending $10K for a couple holes, but you might know someone with access to a tool like this.
If it is in place on the car, as Bob mentioned there are two piece punches (with mandrel) that come in various shapes and sizes.  You drill a hole first for the mandrel (which is smaller than the die), and then torque down on the die, either with a ratchet (poor mans version) or with a hydraulic ram.   Electrical based tools are the most popular.  Google "Greenlee Hole Punch".  A sample picture is also attached.  The most common as you can imagine are for 1/2, 3/4, etc. conduit fittings, and they are round.  But there are many many sizes and shapes out there, you just need to look.
With a mandrel based tool, you really need to get the exact shape die.  With an ironworker, you can if needed use smaller dies and nibble away at making a larger shaped hole, making it much more versatile.
Re: Drop off holes
« Reply #6 on: October 08, 2015, 09:05:07 PM »
Of course the holes will not be seen once the car is together - wish the reproducers would just make them correct to begin with. Its just easier to make one size fits all and let the owner/shop deal with the details :(
Re: Drop off holes
« Reply #7 on: October 08, 2015, 10:22:16 PM »
I've use this type of metal nibbler tool for more years than I wish to reveal. Available from Amazon -
http://www.amazon.com/Hand-Sheet-Metal-Nibbler-Cutter/dp/B000T5FV4Q/ref=sr_1_7?s=hi&ie=UTF8&qid=1444353033&sr=1-7&keywords=sheet+metal+nibbler
You need to drill a pilot hole big enough for the nibbler head, but smaller than the hole you need. It makes square holes easily, round holes are better made by a chassis punch (see Greenlee on e-bay). The biggest problem is drilling a pilot hole in an installed piece of sheet metal, a right angle drill adapter "works" sometimes.
Re: Drop off holes
« Reply #8 on: October 09, 2015, 01:26:39 AM »
Why not drill the holes as you proposed and do the carving on the rubber drain's square fitting ?  Brian
