Author Topic: 69 sport mirror mounting  (Read 1893 times)
Offline emptys
« on: October 06, 2015, 02:59:54 PM »
What's the correct mounting for driver and passenger size sport mirrors?
Is it nut-serts on both sides, or did the passenger side just use screws...
« Last Edit: October 06, 2015, 07:34:30 PM by carlite65 »
69 428 GT -- 9F02R -- build date 10/11/68
Offline cobrajetchris
Re: 69 sport mirror mouning
« Reply #1 on: October 06, 2015, 05:16:28 PM »
I would say with reasonable confidence if the car came with sport mirrors from the factory it would have the nut inserts the same as the driver side. Even if for some reason the car did not come with them I would install them anyway as a thin sheet metal screw is not going to hold the mirror on for long.
CHRIS KNOBBE
« Reply #2 on: October 06, 2015, 07:31:36 PM »
To use the original mounting machine screws that were used for mounting these mirrors a nut-sert needed to be mounted in the door. These specific screws have four additional "hash marks" between the Phillips screw depressions
Sorry that they are not more visible in this picture
Re: 69 sport mirror mounting
« Reply #3 on: October 06, 2015, 08:36:14 PM »
...and the letter S.  Look at the 5 o'clock position.  Brian
« Reply #4 on: October 06, 2015, 11:26:14 PM »
You might wish to check the Library under topic "Mustang Hardware Spreadsheets 69-70" and open spreadsheet file "MHW69-70AP01.xls". This file lists the hardware by Location-Application and under "Mirror. . . " you find the part numbers and descriptions.
« Reply #5 on: October 07, 2015, 12:07:45 AM »
Don't think I've seen the S on many originals (might be a different vendor)
Will dig out the hand full I've got in one of the organizers at the show and take a picture.
