Author Topic: Correct 4 Speed ?  (Read 9470 times)
Offline petersixtfive
Re: Correct 4 Speed ?
« Reply #30 on: September 16, 2018, 04:55:50 AM »
Brian
For reference
The date numbers from the T10 4 speed in my 65 GT
E255 1
May 25th 1965
Shift1
Cheers
Peter
« Last Edit: September 16, 2018, 04:59:24 AM by petersixtfive »
« Reply #31 on: October 31, 2018, 08:53:00 AM »
Had the  T-10 trans w/HEK-V tag rebuilt and learned a couple of things.  This is a WIDE RATIO trans.  Earlier I had miss identified it.  The speedometer drive gear is the 6 tooth variety.  Brian
« Last Edit: November 03, 2018, 08:36:04 PM by Brian Conway »
Offline ChrisV289
« Reply #32 on: February 16, 2019, 12:13:38 AM »
Was going through threads to try and determine which 4 speed my blue fastback came with originally.  Brian, your car is built about 3 days before mine and is also caspian blue but not a GT.  Am I safe to assume my car would of had a t10 transmission in it as well?
2009 V6 Mustang Coupe
« Reply #33 on: February 16, 2019, 10:26:45 AM »
Can't help with a definitive answer.  Do seem to be a number of members with similar dates, T-10's and the same question ?  At this time gathering supporting information for an early assembly line installation of the T-10 is in progress ?  Brian     http://www.concoursmustang.com/forum/index.php?topic=19730.msg124673#msg124673
« Last Edit: February 17, 2019, 12:16:54 PM by Brian Conway »
