Author Topic: Seatbelt Bolt Identification  (Read 3030 times)
Offline Stangly
  • Gold Level Subscriber
« on: September 25, 2015, 09:44:08 PM »
I could sure use some help identifying the correct location of these seatbelt bolts.  They are from my 69 Dearborn car early June build date.  The car came equipped with shoulder belts.  The bolts in the first pic are longer and two of them have a rubber washers on them and also two chrome spacers.  The second pic contains red dyed flat washers and spacers.  And the last photo has shorter bolts I believe these are for the rear seat.
Thank you!
68 Coupe J-Code
2001 V6 Laser Red
2015 GT Deep Impact Blue
Re: Seatbelt Bolt Identification
« Reply #1 on: September 25, 2015, 10:41:27 PM »
Got a Shop Manual ?  If not couple pages that will be of some help.  Brian
« Reply #2 on: September 26, 2015, 12:24:03 AM »
Thank you!
If you go to the Library section of this forum under topic "Mustang Hardware Spreadsheets 69-70", you will find two downloadable spreadsheet files, one by application (MHW69-70AP01.xls) and one by part number (MHW69-70PN01.xls). In the application file under "Seat Belt, . . " you will find the description of the three different bolts and three different washers.
Offline Stangly
« Reply #3 on: September 26, 2015, 02:37:42 AM »
Thanks guy this helps a ton. Brian what manual are the pics out of.  I have the assembly manuals and the repair manuals.  The assembly manuals I have are missing the interior section.  With Jim's spread sheet and these pics I should be able to wade thru it.
Thanks a bunch and have a great weekend!
68 Coupe J-Code
2001 V6 Laser Red
« Reply #4 on: September 26, 2015, 08:48:09 AM »
Volume # 4
« Reply #5 on: September 26, 2015, 03:47:05 PM »
Volume # 4
For clarification those are the "shop manuals" that the poster mentioned earlier. Those are not to be confused with the assemblyline manuals which are different.
Offline Stangly
« Reply #6 on: September 27, 2015, 02:01:09 AM »
I have the body assembly line manual but didn't see anything on seatbelts.  I made the stupid assumption that the information would not be in the shop manual.  I found information on several items on the interior that I had questions on in the shop manual. http://www.concoursmustang.com/forum/Smileys/default/embarrassed.gif
Thanks again guys,
68 Coupe J-Code
2001 V6 Laser Red
Offline Andrew@MagMustangs
    • MagMustangs
« Reply #7 on: October 01, 2015, 05:36:02 PM »
#3 are the Rear Seat Belts.
#1 are the Front Floor Belts.
The chrome washers are for shoulder harnesses which you do not show bolts for. The chrome washers go between the belt mount tab and roof.  Shoulder harnesses use a bolt with a shoulder about 1/2 the length of the front floor bolts. I use the term 'shoulder' to refer to the smooth, non-threaded section between the bolt head and the threads.
Red dimpled washers are for the rear seat bolts. You will want to use the shop manuals for reference on how the washers are all placed, I usually find differing placements depending on if the car had been messed with, or not. Rubber washers are for front floor bolts and same with wide metal washers which should be under the belts/retractors, touching the floor, under the carpet.
