Author Topic: Suspension Alignment  (Read 4574 times)
Offline Building 3
« on: September 23, 2015, 12:10:48 PM »
I recently had my suspension aligned.  The car was equipped with bias ply tires when it was done.  I am now switching over to radial tires for the fall driving season.  Would the switch in tires make a difference to the caster, camber and toe-in settings on the front suspension? Thanks.
Offline suskeenwiske
  • 214-347-3628
Re: Suspension Alignment
« Reply #1 on: October 06, 2015, 11:02:26 PM »
I had a 1975 Camaro with Bias Ply Tires. Switching to radials didn't require a new alignment but that was a different make and had 10 years of updated engineering. Probably best to discuss with the Service or Tire Shop.
Ray
Ray
1965 Dearborn Coupe
6 Cylinder, AT, PB, PS, AC
Est. Build 23A
« Reply #2 on: October 06, 2015, 11:32:02 PM »
Both my 65 GT Fastback and 66 "A" code Hardtop have radials without any changes to alignment. They both ride great.
« Reply #3 on: October 07, 2015, 11:56:06 AM »
As a owner of a Tire Alignment Shop and having been aligning cars since about 1980 professionally, I can agree with the previous responses.
Fine-Tuning of wheel alignments is usually based upon driving habits and road conditions, detectable by reading the tire's wear pattern, not usually because of tire design.
(enter the usage of a tread depth gage here)
NASCAR settings will be different than yours, for example ;)
« Last Edit: October 07, 2015, 11:58:54 AM by 67gtasanjose »
Offline dave6768
« Reply #4 on: October 07, 2015, 10:41:15 PM »
Changing wheels and tires will not change the alignment.  However, my understanding is that may want slightly different values for radials.  For example a bit more caster.
Offline WT8095
  • Dave Z.
« Reply #5 on: October 08, 2015, 10:46:15 PM »
The '68 shop maual lists a single set of alignment values for all Mustangs for that year - no distinction by tire type or size. Inflation pressures, on the other hand, are listed as varying based on a number of factors.
Dave Z.
Offline dave6768
« Reply #6 on: October 08, 2015, 11:00:10 PM »
I don't believe Ford put radial tires on a 68 Mustang.  All the alignment specs were for bias ply.
"In 1970, Ford Motor Company produced the first American-made vehicle with radial tires as standard equipment, the Lincoln Continental Mark III."
Offline WT8095
  • Dave Z.
« Reply #7 on: October 08, 2015, 11:41:53 PM »
The tire inflation chart ('68 shop manual again) lists optional radial tires for all five car models it covers - Cougar, Fairlane, Falcon, Montego, Mustang.
« Last Edit: October 08, 2015, 11:46:45 PM by WT8095 »
Dave Z.
Offline WT8095
  • Dave Z.
« Reply #8 on: October 08, 2015, 11:46:13 PM »
This is from the '67 Mustang brochure. First year for radials on Mustangs.
Dave Z.
« Reply #9 on: October 09, 2015, 11:42:31 AM »
Believe there is some documentation that shows late '66 model year cars could be ordered with radials also.
Offline dave6768
« Reply #10 on: October 09, 2015, 12:45:29 PM »
I guess I should quit while I'm behind.  LOL.
Offline WT8095
  • Dave Z.
« Reply #11 on: October 09, 2015, 02:56:47 PM »
Don't feel bad - I didn't know these details myself until I started looking based on your question. Now we've created a resource that others can turn to for these answers. It would be cool to locate a source for the late '66 application that Jeff mentioned and add that to the topic too.
Dave Z.
Offline Toploader
« Reply #12 on: October 09, 2015, 04:51:47 PM »
>>> Charles.
76A-Y-D2-13H-72-6-6
Offline WT8095
  • Dave Z.
« Reply #13 on: October 09, 2015, 06:31:06 PM »
>>> Charles.
Oops, yes, shouldn't have gone from memory on that one...  :-[   My apologies Charles!
Dave Z.
