Author Topic: '68 Starter Solenoid problems  (Read 11288 times)
Offline mikelj5S230
  • 1964 1/2 K code coupe, 5S230, and 2022 GT500 HE
« on: September 21, 2015, 07:45:11 PM »
I have a "correct" Autolite repop that has given me trouble, it stuck engaged so the starter was engaged while the engine started and idled.  I was able to quickly shut everything down before any damage happened, and after disconnecting it all and reconnecting it it has started fine with no problems.  But, I do not trust it so I am replacing it with a reliable NAPA unit, not correct looking but it will work all the time.  Anyone have any tips about any of the "correct" repops being any good, or all they all Chinese junk?  And if they are all junk, what do you all do for "concours correct" solenoids that actually work? Thanks.
I don't always downshift, but when I do it is near a Prius so they can hear me hurting the environment.
Re: '68 Starter Solenoid problems
« Reply #1 on: September 21, 2015, 09:12:54 PM »
I have heard that the AMK produced concours-correct starter solenoids aren't very reliable.  I have no personal knowledge of this, only repeating what was stated in other forums.
« Reply #2 on: September 21, 2015, 10:22:57 PM »
Your options are find a original good enough to restore (replate the bracket),find a NOS unit , or keep a couple repros on the shelf in case one fails . The OEM Ford ones virtually never failed.
Offline dave6768
« Reply #3 on: September 21, 2015, 10:34:17 PM »
I too had the same problem.  I ended up cleaning up my 30 year old unit.  Lucky for me, all the plating was still in great shape.
« Reply #4 on: September 21, 2015, 10:44:45 PM »
I had the exact same problem too on a 66 car just 4 days ago. I replated the bracket of a used original unit I had in my stand by pile to solve the problem. It looks great and I can depend on I too.
« Last Edit: September 22, 2015, 12:50:42 AM by Bob Gaines »
Offline mikelj5S230
« Reply #5 on: September 21, 2015, 11:37:03 PM »
I have a good local electronics restoration guy who thinks he can swap the good guts of the NAPA unit into the correct and new looking Chinese Autolite junk exterior case.  I may let him try that.
« Reply #6 on: September 22, 2015, 12:12:47 AM »
I have had this problem with several of the reproductions and as said above I now restore originals.
« Reply #7 on: September 22, 2015, 06:20:00 AM »
OK, rebuilding the original is the way to go if you have a good used available (and I do)
Re plating the mounting bracket seems easy enough to do, and sending the bracket out with several other like finish items to be plated together at the same time, would seem to be the most reasonable for pricing.
These were riveted together units and I am sure there are contacts inside that should be filed or sanded to improve internal connections. A source of the rivets would be extremely helpful.
I had already been considering if it was practical to rebuild one (my original) or buy one aftermarket (from Marti Auto Works ~$38) or simply use a later D2 service piece (though not Concours). Decisions, Decisions.
I have concerns about any notion that original "guts" would fit into any aftermarket parts/pieces but I suppose the bracket itself from off of a reproduction solenoid would easily be moved to a later service piece Motorcraft solenoid.
Maybe an ARTICLE in the library put together by someone who has already walked this road would be a DYNOMITE idea? Just asking...
« Last Edit: September 22, 2015, 06:44:23 AM by 67gtasanjose »
« Reply #8 on: September 22, 2015, 10:35:39 AM »
Someone with more time then I will have to do a article. One of the problems with the repro is that they seem more susceptible to problems like  when tightening the wires on the side posts is that you have to hold the inner nut as you tighten the outer nut. If you don't the possibility of the post slightly twisting or turning could result . That twisting translates into the contact points mis aligning inside the body . A light misalignment results in less contact between the two pints which can result in more resistance = heat = sometimes enough to weld = contact points sticking together  = starter remaining in gauged until battery is disconnected or knocked loose with a hard hit to the solenoid top.  Same caution needs to be exercise with originals but originals don't seem to be as susceptible as the repros.
Offline drummingrocks
« Reply #9 on: September 22, 2015, 10:54:24 AM »
I, too, have struggled with the repro AMK solenoids.  The one on my '69 Mach stuck closed almost immediately after installing it.  Now, I use a NAPA brand solenoid when I'm driving to and from shows, and swap in the repro solenoid once I'm on the show field.
Offline Laurie S.
  • Trouble
    • My 1968 Mustangs
« Reply #10 on: September 22, 2015, 07:04:56 PM »
I had an AMK solenoid stick on me, too.  I restored an original and carry an electronic one with me, just in case.
Murphy, 1968 Coupe - Concours, Original Owner
Trouble, 1968 Fastback - Modified
MCA Gold Card Judge, 67-68 Concours
MCA Gold Card Judge, Modified - All Years
« Reply #11 on: September 22, 2015, 09:45:29 PM »
I harvest solenoids from old Fords found in junkyards for customers that might be interested in them.  Although not in the best cosmetic shape, they probably were not the reason for the car being in the junkyard.
Offline 70 Cougar
« Reply #12 on: September 23, 2015, 04:59:59 AM »
The repro units are garbage.  Had a brand new one fail on the 2nd or 3rd start up and that's with solid grounds and a fully charged battery.
Steve O
1970 Mercury Cougar
Offline rockhouse66
« Reply #13 on: September 23, 2015, 08:49:11 AM »
Very curious how you replate one of these solenoids.  How do you remove the top bracket?  Do you drill the rivets and remove and replate the bottom plate too?  Then how do you reattach these to look as if you hadn't worked on it?
'66 GT FB
« Reply #14 on: September 23, 2015, 08:53:15 AM »
+1
Why I asked for those who have already "walked the road" for help. Maybe I shouldn't have asked for an "article" ;)
