Author Topic: Color and finish for fastback trapdoor backside - Early 65 San Jose  (Read 5560 times)
Offline livetoride60
Was wondering what color the backside (trunk facing) of my trapdoor would have originally been for my Oct 64 San Jose fastback.  Interior is white / black, code D6.  Front side of trapdoor was white, but backside was covered with carpet.  Unfortunately the body shop media blasted the trapdoor before I could look.
The first two pictures are my car.  It looks like the hinges were originally white, and then may have had their lower halves painted black, I assume during an amateur resto.  From the hinges, could I assume it was white originally?
The last two pics are from Jeff of a black trapdoor and from ChrisV of what looks like an ivy green from his car.  (Hope it was ok to repost).  Also note that it appears the hinges were ivy green as well in the last pic, matching the trapdoor color.
Finally, what would the paint finish be?  Looks like a satin or dulled like other interior pieces.
Any info would be appreciated.
Rich
'65 K code Fastback, 4sp, San Jose, 10/9/64
'66 C code Coupe, C4, Dearborn, 5/24/66
'67 Fairlane Convertible, 3sp, 200 I6
Re: Color and finish for fastback trapdoor backside - Early 65 San Jose
« Reply #1 on: September 16, 2015, 08:21:08 PM »
Close up of the hinge.  Looks like original white with black paint or black adhesive slopped on the bottom.  I maybe can make out white behind the hinge too.
Offline ChrisV289
« Reply #2 on: September 16, 2015, 10:44:26 PM »
If the fiber glass panels in the back are white so is the trap door on both sides...Mine is pretty flat not gloss really (color code 28).  OK to re-post my pics ;)
« Last Edit: September 16, 2015, 10:46:48 PM by ChrisV289 »
2009 V6 Mustang Coupe
« Reply #3 on: September 17, 2015, 02:41:38 AM »
Back side of the trap door is the same as the interior. The "fiberglass" side panels have nothing to do with it - originally they would be unpainted on the back side - sort of a light tan finish that matched the base color of the material used to make them. Ford/the supplier didn't paint he back sides so they often contrast and are something just about every judge checks as they are often painted :(
Example - Interior is black
Finish would be exactly (same paint and painter) as the interior. Closer to satin (very slight shine in the right light and angle) often referred to as egg shell in today's terms
On this year hinges were painted the same color/finish but before they were attached to the trap door or car
65 San Jose white interior example
« Reply #4 on: September 17, 2015, 05:30:56 PM »
Thanks Jeff and Chris.
Another one,  is the finish on those hinge screws P &  O?  They look dark.
« Last Edit: September 17, 2015, 06:03:22 PM by livetoride60 »
Offline rockhouse66
« Reply #5 on: September 17, 2015, 07:17:03 PM »
On an early '66 SJ car, they are red.
'66 GT FB
« Reply #6 on: September 17, 2015, 07:37:25 PM »
They were a dark flat finish from just a look (not testing ;) I believe P & O would reproduce the look well
From 5R150xxx
Sure someone will notice the factory runs (not typical) and the direction of travel
Since their related and they may help you or someone in the future here are a couple of extras ;)
Never seen that before on an unrestored car. The red die didn't get wide usage until 68 following the strike
Not sure why the trap door would be a safety issue
« Last Edit: September 17, 2015, 07:57:22 PM by J_Speegle »
Offline rockhouse66
« Reply #7 on: September 19, 2015, 09:56:08 AM »
Jeff - yes, restored car using AMK hardware kit.  I don't know where Max got the idea these were red.  The assembly manual shows S2 (P&O) finish on these.
The red looks cool though doesn't it?  :D
'66 GT FB
« Reply #8 on: September 19, 2015, 04:11:59 PM »
Would guess that he's just selling one hardware set for two or more purposes. Looks like they are the same size as the ones used to hold the 69-70 rear seat (sportroof) latches to the body and those were dyed red as a safety measure
« Reply #9 on: September 19, 2015, 04:49:11 PM »
In one of a few conversations with AMK, they indicated that the hardware they sold was based on the Ford Car Parts books (aka MPC, years unknown), which did not reflect what the factory used for initial assembly, but what Ford supplied to dealers for service use. If the difference was plating on several hardware items, low use items not plated were included in higher use items that were. Ford did that to reduce inventory counts, inventory costs and space requirement. Part of their "inventory plan" was to establish minimum order quantities too, hence the infamous "bag of five" of something that you ordered that had a use of one or six. This bag quantity was for a replacement at a dealership, not a restoration in your garage.
Offline C5ZZ
« Reply #10 on: September 20, 2015, 01:07:31 PM »
At some point the hardware and hinge for the trap door was changed,
smaller screw from my Oct 64 Dearborn build.
MCA # 00945
65 Fastback, 6 cyl, AT, AC, PS, PB
Rangoon Red/Red Interior
« Reply #11 on: September 20, 2015, 02:51:07 PM »
So yours is the upper set of screws?
The first one I posted was from late (24th - projected) Oct 64 San Jose for comparison.
Guess we need to look at earlier fastbacks to find the trend - Believe  that the smaller was the earlier.
« Last Edit: September 20, 2015, 02:53:39 PM by J_Speegle »
Offline C5ZZ
« Reply #12 on: September 20, 2015, 04:42:59 PM »
Jeff, yes, my Oct 64 Dearborn had the smaller/darker screws pictured next to the red hinge.
The larger screw and hinge came with a trap door I picked up in a parts lot so can't verify its origin.
The slotted holes in the black hinge for the screws is larger than the slots in the red hinge .
« Last Edit: September 20, 2015, 04:45:25 PM by C5ZZ »
MCA # 00945
« Reply #13 on: September 20, 2015, 05:05:56 PM »
There are two screws in question, 55589-S2, 8-32X1/2 hex sems, and 55590-S2, 10-24X1/2 hex sems. My Oct 65 San Jose 66 Fastback uses 55590-S2 (10-24), my May 65 San Jose 65 Fastback uses 55589-S2 (8-32). This size problem came up for me last month on a friends two 65 San Jose Fastbacks he's getting back on the road, one an Oct 64 build, the other a January 65 build. Both use 55589-S2 (8-32). The 65 Body Assembly Manual (page 47), rev date 4-22-65 (barely legible), shows 55590-S2 (item J) but no reference as to if or when it was changed. This may be another "use existing inventory first" situation. I cannot verify if my 65 Fastback trap door is original.
« Reply #14 on: September 20, 2015, 05:53:07 PM »
Difficult to make out the difference in just a picture. Guess the start washer is the visual tell-tell sign/key for a quick determination.
Not sure if this is a "use existing inventory first" since it appears that this is not a stand alone detail and may connect to the larger holed hinge and mounting holes/nuts.
