Author Topic: Fall,Winter storage windows cracked or closed  (Read 5176 times)
Offline gimpystoy
« on: September 14, 2015, 02:45:40 PM »
I'm looking for advice for Nov to April storage. 67 fastback,  Location: Southern N.J. Attached garage.  Should the windows cracked? Or vent wings cracked. Interior restoration finished this past Spring/Summer.
TY,Gimpy
67 C code Metuchen, May "67" build 289 C4
Offline WT8095
  • Dave Z.
Re: Fall,Winter storage windows cracked or closed
« Reply #1 on: September 14, 2015, 03:29:23 PM »
Will you be using the garage for other vehicles? Parking a wet vehicle (snow/ice/mud, even rainwater) in a shared space will create a bunch of water vapor to deal with. Keeping the windows closed should minimize how much of that gets into the interior. But that moisture is going to affect exposed metal under the car and in the engine compartment a lot more severely.
« Last Edit: September 14, 2015, 11:23:36 PM by WT8095 »
Dave Z.
Offline gimpystoy
« Reply #2 on: September 14, 2015, 03:37:00 PM »
Thanks: Fortunately the other bay is occupied by my Son's  87 Buick Grand National. It's  not running currently (engine work). The garage doors will only be opened briefly throughout storage.
Gimpy
Offline markb0729
  • South Jersey
« Reply #3 on: September 14, 2015, 05:38:56 PM »
If your garage floor is not sealed, you may want to consider putting down a floor protector such as G-Floor.  It acts as a vapor barrier.
65 Dearborn Built Fastback
289 4V, C4, PS, PB, No A/C
Offline mikelj5S230
  • 1964 1/2 K code coupe, 5S230, and 2022 GT500 HE
« Reply #4 on: September 14, 2015, 08:56:42 PM »
I keep my windows rolled up tight, keeps dust and "things" out.  The biggest problem you will have is condensation on metal parts as it gets cold and humidity comes in behind the cold.  Flash rust can happen overnight it seems, as well as corrosion on wet aluminum parts too.  Not much you can do except install a dehumidifier.
I don't always downshift, but when I do it is near a Prius so they can hear me hurting the environment.
Offline sgl66
« Reply #5 on: September 14, 2015, 10:54:09 PM »
http://www.carbag.com/
Comes out in the spring exactly as you put it away in the fall.
Temp swing from 20 one day to 60 and raining the next...the inherent condensation that comes will never touch your car.
Offline WT8095
  • Dave Z.
« Reply #6 on: September 14, 2015, 11:22:45 PM »
What a great idea! Pay attention to their caution about not washing the car immediately prior to storage. If the bag keeps moisture out, it will also keep it in. If there's enough you can still get evaporation/condensation cycles. Don't seal it up on a really humid day  ;)
Dave Z.
Offline gimpystoy
« Reply #7 on: September 15, 2015, 11:53:10 AM »
Good info As always from CMF Community.
TY,
Gimpy
Offline preaction
« Reply #8 on: September 28, 2015, 09:02:43 PM »
Gimpystoy, where is the south of jersey are you ? Im in Deptford I may be able to help, Paul.
Offline Cobrajet428
    • Photos of my '70 Mach 1 428Cj 4-spd
« Reply #9 on: October 02, 2015, 01:52:47 PM »
I've used a CarBag on my '70 Mach 1 for years and would swear by its ability to preserve the car while in storage. Not only does it keep moisture at bay (using the desiccant as prescribed), but it keeps mice away. All you do is unzip it, lay it down flat, drive your car over the bottom part, remove the car's battery, slide a desiccant canister underneath the car, put a cloth cover over the car, a provide protector over the antenna tip (to keep it from poking through the bag, pull the remaining bag over the top of the car, and zip it up.
The bag will last for years with a little caution. Be sure there's nothing on the floor to poke holes in the bag as you drive over it. I throw down a tarp and carpet to protect the bag and that's worked very well. It's easy to use a little duct tape to patch the bag if it comes down to it.
Here's a photo to give you a better idea: https://70cjmach1.smugmug.com/Current-Photos/Storage/n-kmZnRQ/i-bzddCDL
Offline WT8095
  • Dave Z.
« Reply #10 on: October 02, 2015, 02:01:36 PM »
I've used a CarBag on my '70 Mach 1 for years...
Sweet! What do they run for price? How big is the dessicant container? Do you regenerate the dessicant yourself?
Dave Z.
Offline Cobrajet428
« Reply #11 on: October 02, 2015, 02:13:06 PM »
They are in the neighborhood of $200-$300, but you should check on the website to see. FYI - I've always had good luck reaching them by phone with questions. Great people to deal with!
I believe the bag comes with a bunch of palm-sized paper packets of desiccant, but that you can order a much more convenient canister (about 6" diameter, 2+ feet long) separately. They can both be re-used indefinitely by going through an easy oven-baking process, just before you're ready to put them into use. The packets are cut open and dumped into your own tray for baking and re-use (you then use the tray full of it under your car), but the canister can just be placed into the oven (your kitchen oven and no it won't smoke up the house or make a mess), baked, and then wrapped in aluminum foil to keep it sealed before you're ready to use it. You need it put it into use very soon after baking through. CarBag provides all this information in detail.
I actually use both a tray full of the desiccant and a canister, as you can never have too much!
« Reply #12 on: October 04, 2015, 05:12:42 PM »
Will not hurt to throw a dozen or so dryer sheets in the interior also. Place them on something so that they don;t contact the interior materials
Offline GT500KR
  • Charlie Ping
« Reply #13 on: October 05, 2015, 09:54:39 AM »
+1 On the dryer sheets. The critters seem to hate them. ;)
I like to close my doors on the first click while in storage. (With car cover, and indoors). I feel like it offers a bit of air circulation, plus it keeps the seals from taking a "set". My 2 cents.
Current Project:
64.5 Black DB Cpe
5F07D1131XX  4/14/64
The stable:
65 Ivy Green Coupe 4SPD
68 Candy Apple Red GT500KR 4SPD FB
70 Grabber Blue Boss 429
86 JalapeƱo Red GT  5SPD
91 Emerald Green Saleen Conv. 5SPD
03 Sonic Blue Cobra Conv.
07 Black GT500 Cp
Offline mikelj5S230
« Reply #14 on: October 05, 2015, 11:51:06 AM »
That is superior to mothballs, but probably not as long lasting.
