Author Topic: FORD HOSE CLAMP  (Read 1878 times)
Offline 69cobrajetrugae2
FORD HOSE CLAMP
« on: September 14, 2015, 09:58:27 AM »
This clamp was on the fuel line on my 69.  I didn't know that Ford made worm style hose clamps. Were these clamps installed on my car?  I tossed it on a buffer wheel and it appears to be at least 316 stainless.  There are numbers stamped on the clamp as well. Please Advise.
« Last Edit: September 14, 2015, 10:02:50 AM by carlite65 »
Re: FORD HOSE CLAMP
« Reply #1 on: September 14, 2015, 01:37:20 PM »
Typically you see the worm drive "sure tight" worm drive clamps holding the P/S return and pressure line at the control valve on later 67-70 Mustangs.I can't remember seeing a application where it was typical to see a worm drive used on the fuel line from the factory. Maybe others?
Re: FORD HOSE CLAMP
« Reply #2 on: September 14, 2015, 03:31:11 PM »
Thanks Bob!  That's where it's going to be installed.
Offline JKWilson
Re: FORD HOSE CLAMP
« Reply #3 on: September 14, 2015, 06:11:02 PM »
I discovered Ford worm drive clamps on a '92 SSP LX I bought. They were on the heater hoses and radiator hoses. While not necessarily applicable to the vintage cars, my point is they continued using them on later cars too.
Re: FORD HOSE CLAMP
« Reply #4 on: September 14, 2015, 08:28:14 PM »
iI can't tell for sure but it looks too small for the control valve.
Offline MattDoscher
Re: FORD HOSE CLAMP
« Reply #5 on: September 14, 2015, 10:47:03 PM »
Quote
I pulled the fuel pump on my '91 Grand Marquis recently and the rubber hose on the fuel pump had the exact same type of worm gear clamps.
Matt Doscher
5H25T582252
