« Reply #1 on: September 13, 2015, 07:25:53 PM »
Can these be found NOS ? or can or more importantly does someone replace the factory lines using the factory ends. Im going to guess here that the end parts are a 67 only thing.
Probably somewhere you could find NOS but they are extremely rare in that form . I have never come across a NOS set of 67 lines in all my years . Maybe someone else has had more luck then I have . I have networked with quite a few sellers and swap meets over the years so it wasn't for lack of trying. If you did find some no doubt they would be very expensive given supply and demand. Obsoleted in early 68 production as you can guess. You have to be careful because many times sellers will advertise "NOS A/C Lines" and they are different then assemblyline. There are quite a few NOS hang on A/C kits out there but the long lines are different then what came on the 68 69 cars let alone the 67 cars. The old kits are where many source various parts from. Some parts are OK to use as assemblyline and some are not .The trick is knowing which is and which isn't. No one I am aware of that makes them up with the correct ends as far as I know. Wish they did. Excellent used is the best you can hope for I am afraid.
« Last Edit: September 13, 2015, 07:29:54 PM by Bob Gaines »
Logged
