Author Topic: 70 lower grille pane & fender extension moulding paint  (Read 1738 times)
Offline kcodecoupe
« on: September 13, 2015, 09:50:36 AM »
i am going to paint both front fender extension mouldings and lower grille opening panel with the argent color on my jan built metuchen 70, and looking for a picture and tips or diagram to show how much gets covered with argent color on these pieces , thanks.
« Last Edit: September 15, 2015, 08:16:49 AM by kcodecoupe »
Re: 70 lower grille pane & fender extension moulding paint
« Reply #1 on: September 15, 2015, 06:28:41 PM »
Just the mid large flat surface. Reflections can produce some misleading tells in the pictures - the reason for multiple angles ;)
Guess I would use pinstripe tape for the edges then just mask the rest of the surface before painting
Offline kcodecoupe
« Reply #2 on: September 16, 2015, 09:16:49 PM »
Jeff, thank you so much thats just what i needed, i can get these done now before the cold weather hits.
« Reply #3 on: September 17, 2015, 02:21:36 AM »
Glad to help
Offline machm1970
« Reply #4 on: September 25, 2015, 08:03:58 PM »
I'm going to do this on my '70 as well. Is the correct paint just called "Argent"? I'm going to order it from NPD if that's correct? Also are the plastic headlight bezels painted Argent as well?
Matt
Offline machm1970
« Reply #5 on: September 25, 2015, 08:08:33 PM »
All is see listed in spray cans is "Argent wheel paint" is this correct for the grill moldings as well?
Matt
Offline rockhouse66
« Reply #6 on: September 25, 2015, 09:59:49 PM »
Be sure to get the dark argent for the grill area, like this one;
http://www.cjponyparts.com/scott-drake-grille-rocker-panel-paint-mach-1-1970/p/PTDKARG/
'66 GT FB
Offline machm1970
« Reply #7 on: September 25, 2015, 11:24:33 PM »
Thanks Jim!
Matt
