Author Topic: Seam sealer inside trunk -wheel houses, etc  (Read 2503 times)
Offline 68JCode
« on: May 18, 2010, 09:28:17 PM »
What is the best product to duplicate the seam sealer around the wheel houses inside the trunk?  The product from the factory looked more like sprayed on Schutz texture in these areas, but only along the seam (1" wide or so?
'68 Fastback SJ assembly.
Andrew
Re: Seam sealer inside trunk -wheel houses, etc
« Reply #1 on: May 18, 2010, 09:37:38 PM »
You can use the same heavy build up products you would use on the rear wheelwells or on the trunk side of the rear quarterpanels
I've used a sound insulator product others like Wurth or similar stuff
Original examples I have show a pass of product much wider than 1" but it would differ from day to day - worker to worker at that plant, that year
Offline bryancobb
  • Silver Level Subscriber
  • 2009 Ridn' Around
« Reply #2 on: May 19, 2010, 07:59:41 AM »
Google and watch the application video for LORD FUSOR 805 and 804.  You'll be amazed!
66 Metuch Conv
Nightmist, Std Blu Int
Offline buckeyeresto
« Reply #3 on: May 19, 2010, 08:33:50 AM »
the fusor or the 3m version mentioned above works the best, need special applicator gun that sometime jobbers rent out
Offline bryancobb
  • 2009 Ridn' Around
« Reply #4 on: May 20, 2010, 07:52:06 AM »
That SPECIAL GUN is THE SECRET to perfect results!  They are on Ebay for $175.
66 Metuch Conv
