Author Topic: Steering Box Ratios  (Read 1521 times)
Offline Building 3
Steering Box Ratios
« on: September 06, 2015, 07:03:03 PM »
1966 MY: Is there an internal or external difference between the 16:1 ratio manual steering box HCC-AX in the handling package and the 16:1 power steering ratio box HCC-AW? It seems odd that Ford would offer two boxes with the same ratio instead of one. Perhaps the Handling Package box is more heavy duty?
Offline Asm109
Re: Steering Box Ratios
« Reply #1 on: September 06, 2015, 07:23:24 PM »
The difference was in the preload specs.  The torque required to turn the shaft is higher on the manual steering box.
I think they did this because the forces on a manual box are higher than on power steering.
« Reply #2 on: September 06, 2015, 08:19:17 PM »
Physically both the HCC-AX and the HCC-AW are the same, and as such - interchangeable but, as noted, have different preload torque specs. There was a local shop that specialized in steering box rebuilding (I think he is gone) and years ago, when I asked him about rebuilding my GT box, what the differences were between a 16:1 PS box or a 16:1 manual box told me he bench tested them the same. The real world vs the design spec world.
Offline Building 3
« Reply #3 on: September 07, 2015, 12:10:19 PM »
Thank you very much.  That makes sense and it is a really simple reason.  The same box but with difference specifications.
