Author Topic: correct hole for radio antenna cable  (Read 1207 times)
Offline kcodecoupe
« on: August 27, 2015, 09:41:35 PM »
which hole in the right side cowl panel is for the radio antenna cable to go through on a 70 sports roof, a picture would be great, thanks.
Re: correct hole for radio antenna cable
« Reply #1 on: August 27, 2015, 10:55:56 PM »
Top picture appears not to use the typical hole but does show (not the greatest) antenna cable clip  right at the grommet at the time of the picture and the grommet.
The lower picture is where they were routed through (red arrow) through. That may be the retainer clip and insulator at the purple arrow
Early Dearborn
Offline kcodecoupe
« Reply #2 on: August 29, 2015, 09:11:36 AM »
Thank you for posing the pictures jeff, the lower hole is what i will use, it also has a small hole for a retainer clip right below it ,
Offline Anghelrestorations
    • Anghel Restorations
« Reply #3 on: August 29, 2015, 12:00:41 PM »
You can also find additional details and pictures you wanted on this article I put together earlier this year:
http://anghelrestorations.com/uploads/3/1/7/6/3176630/antennas_v1.1.pdf
Marcus Anghel
www.anghelrestorations.com
