Author Topic: Nut on starter stud - 67  (Read 1463 times)
Offline gimpystoy
« on: August 20, 2015, 12:30:35 PM »
I've repaired the buggered threads on my starter stud. Is the attaching nut copper, brass or steel? I have all three. Which would be correct 67 ?
I think the copper or brass would lower the chances of buggering the stud again.
TY,Gimpy
« Last Edit: August 24, 2015, 09:05:24 PM by J_Speegle »
67 C code Metuchen, May "67" build 289 C4
Re: Nut on starter stud
« Reply #1 on: August 20, 2015, 01:59:08 PM »
It's a steel nut and steel washer. The original may be a nut with an attached external tooth lock washer like the one used at the solenoid but I have not found documentation to support that.
Offline gimpystoy
« Reply #2 on: August 20, 2015, 05:26:04 PM »
Jim thanks.
If someone chimes in on the external tooth washer I have that too.
Gimpy
Re: Nut on starter stud - 67
« Reply #3 on: August 24, 2015, 09:19:16 PM »
Think you forgot to include what engine the car was - just in case it means a completely different answer might result in that little detail ;)
Looking at 6 cylinder application that year - thin steel nut with intergrated exterior toothed washer (star washer
Offline gimpystoy
« Reply #4 on: August 29, 2015, 04:18:26 PM »
Jeff : it's a 67 289.
« Reply #5 on: August 29, 2015, 05:07:29 PM »
Checked and didn't have a nice clear picture of a 67 original - only NOS and service replacements :(
6 cylinder ones are so much easier to get pictures of on the car
« Reply #6 on: August 29, 2015, 06:26:20 PM »
Jeff, I think 6 cylinder starters are the same in this aspect.
Offline gimpystoy
« Reply #7 on: August 29, 2015, 07:51:02 PM »
I have a nut w integral washer off my old solenoid. I'll try it tomorrow
