Author Topic: Shelby Hood Grates  (Read 5753 times)
Offline ddonzella
Shelby Hood Grates
« on: August 19, 2015, 10:59:00 PM »
June 69 Dearborn. I would like to know how the hood grates are supposed to be fastened on the inside of the hood. Couldn't find a post for that item. Maybe they are called something different than a Grate or Grill??
Thank you!
Re: Shelby Hood Grates
« Reply #1 on: August 19, 2015, 11:18:43 PM »
Thank you!
Ones in back are bonded on (JB weld works). Ones in front screwed on. Use the same screws as tailpanel.
Offline ddonzella
« Reply #2 on: August 20, 2015, 11:06:38 PM »
Thank you!
Offline 1970shelbyguy
« Reply #3 on: August 25, 2015, 06:50:51 AM »
add a bit of blk paint to make it look a very dark grey
1970 gt500  grabber blue  june/69     1970  boss 302  metuchen  dec/69
« Reply #4 on: August 26, 2015, 12:16:43 AM »
We just used 2 part (epoxy)  body panel epoxy in black. Wasn't easy to find it in black but was allot easier than painting it later and worrying about little nicks or chips
« Reply #5 on: August 26, 2015, 08:55:45 AM »
i used  grey seam sealer out of a can - mixed in a few drops of blk paint to get it darker- firmed up no problem
Offline ddonzella
« Reply #6 on: September 02, 2015, 11:39:35 PM »
I have the 3M body panel adhesive. It is black and will be perfect for the back grates. I used that stuff to re-adhere the hood to the frame. Front are only screwed in, correct?
« Reply #7 on: September 03, 2015, 12:02:41 AM »
Yes fronts are screwed on. FYI the most prevalent screws are the same distinct type used to secure the top edge of the rear fiberglass tailpanel . AMK sells them for the tail panel.
Offline ddonzella
« Reply #8 on: September 22, 2015, 12:11:37 PM »
Thanks Bob.
Offline ddonzella
« Reply #9 on: September 26, 2015, 06:04:46 PM »
Got the grates off!  What a job! I didn't thick of this but being that I technically have a 70 Shelby GT 350 with the black stripes on the hood, what color are the hood grates supposed to be??
« Reply #10 on: September 26, 2015, 06:46:52 PM »
The grates were unpainted steel. They were a very dark gray hard to tell from black.
Offline ddonzella
« Reply #11 on: September 27, 2015, 12:05:54 AM »
Thanks Bob, Could it be the same color as the front grill?
« Reply #12 on: September 27, 2015, 12:45:16 AM »
Far from it. The grill is a Dark Argent .
Offline ddonzella
« Reply #13 on: September 29, 2015, 12:08:12 PM »
got it!
Offline carm
« Reply #14 on: January 31, 2019, 08:02:24 PM »
Finally I know the truth about the colour of the Shelby hood grates. Actually I wasn't  looking for this detail at all, as I was under the impression that these hood grates were painted black.
So unpainted, very dark grey almost black like a charcoal colour. Would that be similar to phosphate look. They would eventually rust, wouldn't they?
 And was this also the case for the grates in the front fenders and side scoops.
1969 GT350 convertible grabber orange
Auto
Built: April 21,1969. Dearborn
