Author Topic: 64.5 Brake Pedal Finish  (Read 2156 times)
Offline DM_1964
« on: August 19, 2015, 09:48:49 PM »
Just want to confirm if the brake pedal finish should be natural and then 3/4 dipped in satin black?
Mine is a little too rusted on the surface to tell exactly where the paint should finish, but I can see traces of black paint.
I've used a white outlined box around the area I think it should be dipped at if at all in a couple of the pics
Any tips on getting the metal to correct finish would be appreciated as well... thanks in advance.
Regards,
Dom
Online CharlesTurner
Re: 64.5 Brake Pedal Finish
« Reply #1 on: August 19, 2015, 09:55:33 PM »
Yes, end dipped in black.  Soaking these in evapo-rust usually retains some of the finishes like the welds, etc...
Offline GT500KR
  • Charlie Ping
« Reply #2 on: August 20, 2015, 10:47:36 AM »
Here is an example from April 64.
Current Project:
64.5 Black DB Cpe
5F07D1131XX  4/14/64
The stable:
65 Ivy Green Coupe 4SPD
68 Candy Apple Red GT500KR 4SPD FB
70 Grabber Blue Boss 429
86 JalapeƱo Red GT  5SPD
91 Emerald Green Saleen Conv. 5SPD
03 Sonic Blue Cobra Conv.
07 Black GT500 Cp
Offline DM_1964
« Reply #3 on: August 23, 2015, 11:56:54 AM »
Thanks for the reference pic, greatly appreciated ;)
Regards,
Dom
Offline DM_1964
« Reply #4 on: September 29, 2015, 04:48:18 AM »
got to refinishing the brake pedal a few weeks back, I used a similar product to evaporust and soaked the pedal for between 24-48 hours, cleaned up nice, and prepped for paint, I'm happy with the result.
Also threw the pedal support in which was covered in surface rust, that came out really clean as well, I've coated that in Boeshield to maintain the natural finish.
Regards,
Dom
Offline drummingrocks
« Reply #5 on: September 29, 2015, 08:56:32 AM »
Wow, looks great!  What product did you use to soak the parts in?
Offline DM_1964
« Reply #6 on: September 29, 2015, 07:04:55 PM »
Thanks, the product is called Deox, it comes in either crystalized or gel format, the gel is good  when used with a scotchbright pad, and the crystalized is mixed with water to leave parts to soak.
I've used both with great results.
http://www.bilthamber.com/deox-c
« Last Edit: September 29, 2015, 07:40:09 PM by DM_1964 »
Regards,
Dom
« Reply #7 on: September 30, 2015, 09:59:23 AM »
Thanks for the info, it looks like it works really well!
