« Reply #9 on: August 20, 2015, 11:06:06 AM »
So from reading these posts you could have a couple things going on. The horn worked with my Shelby-like La Carra steering wheel before I switched to the deluxe wheel. I had a good used original so i never experienced issues with repros. There are a few adjustments that can be made to the contact points under the deluxe wheel. I did check these before my install to make sure each of the three contact areas were making contact before the install. There are a few articles on the web that discuss this.. At that point is when I ended up moving the column to help make the contact. If your horn never worked, or if you added a new turn signal switch, then of course start with the electrical aspect of it. Good point made by jwc66K, the firewall grommet on the column can be stubborn not to allow the column tube to easily move up or down.
« Last Edit: August 20, 2015, 11:08:11 AM by Hipo giddyup »
Logged
