Author Topic: 67 Courtesy Lights Under Dash, on all cars  (Read 14690 times)
Offline gimpystoy
Re: 67 Courtesy Lights Under Dash, on all cars
« Reply #30 on: August 06, 2019, 06:09:58 PM »
how does socket mount to bracket? Just pushed trough?
67 C code Metuchen, May "67" build 289 C4
« Reply #31 on: August 06, 2019, 07:25:28 PM »
Yes.
« Reply #32 on: August 06, 2019, 08:07:57 PM »
Without a bulb installed. Be advised that the latest offering of 631 bulbs, which is what is used, have a flare at the upper end of the metal where it meets the glass and will not fit.
« Reply #33 on: August 06, 2019, 10:41:09 PM »
The brass socket is pressed into the plated holder/frame.
Offline gimpystoy
« Reply #34 on: August 07, 2019, 07:40:22 PM »
Jeff,ossbill,jwc66k  THAN YOU,
nOW TO GET ONE OF MY GRANDSON'S to crawl under dash and look for plug end.
Offline C6ZZGT
« Reply #35 on: March 23, 2020, 06:35:02 PM »
Can anyone add pictures of the installed lamps ? Both LH and RH if you could.
Brian
66 GT Coupe 6R07A143871 owned since 1983
40+ yr parts man , over 25 with Ford.
« Reply #36 on: March 23, 2020, 07:27:05 PM »
Did you see this related tread?
http://www.concoursmustang.com/forum/index.php?topic=8143.msg46954#msg46954
Offline C6ZZGT
« Reply #37 on: March 23, 2020, 07:41:06 PM »
I have now ,Thanks .
Brian
Offline 196667Bob
« Reply #38 on: March 23, 2020, 08:29:21 PM »
Here are pictures from my 67, January 31, Dearborn Convertible. Excuse the first out of focus picture, but that is all I have. It is the Driver's side, and is the "short body light. The third picture is the Passenger side, and is the "long" body light. IIRC, if the car had Factory A/C, a short bodied one would have been used on the Passenger side.
I have also attached a copy from the 1967 Electrical Assembly Manual.
Bob
MCA 04909
Offline C6ZZGT
« Reply #39 on: March 24, 2020, 01:23:18 PM »
Brian
